[AG-TECH] Osprey Cards....... Desperation
Randy Groves
randy.groves at boeing.com
Mon Aug 9 10:21:56 CDT 2004
The Osprey cards can be set in VidCap as well - select CIF if there isn't a
352x288 selection.
-randy
At 06:15 PM 8/6/2004, John I Quebedeaux Jr wrote:
>Great. On WinXP - on the 288x352 question, I did it by using Regedit...
>from a previous tip awhile back.
>Bring up regedit (for me: command prompt, type regedit)
>Look for: HKEY_CURRENT_USER --> Software --> Osprey --> Osprey100 -->
>Device0 (you should have as many devices as cards installed 0 through x)
>--> VcDll
>Select VcDll and look for Width and Height. Width is 352 (or 160 in hex)
>and Height is 288 (or 120 in hex).
>Rinse and repeat for each card (device).
>If there is another way to do this, I'd love to know. For the WDM I was
>able to do it through VidCap I believe and set it to 288x352 there for my
>4th card.
>-John Q.
>On Aug 6, 2004, at 6:40 PM, Bob Riddle wrote:
>>I'm running on WinXP with AG 2.2 with 3 Osprey cards using the VFW and
>>the "script fix" - it works just fine for me. Remind me again - how do I
>>fix the video to 288x352? I just ran VidCap to set the Video source to
>>svideo for each of the Osprey cards.
>>>Stuart,
>>>I now have a windows xp system with 4 osprey's running with AG 2.1.2.
>>>You have to go back, after the initial installation of the osprey's
>>>current version of the drivers, to install the VfW version of the
>>>drivers. I came across documentation to do just this with the software
>>>that came with the Osprey's. This involved getting the drivers, manually
>>>updating the driver to the older version for each card... rinse repeat...
>>>At least, this is what worked for me. Then, fix the video to 288x352,
>>>s-video, etc.
>>>Then, the problem I had was with 4 cards - while the osprey software
>>>would see them just fine and they were all registered - but somehow the
>>>4th card wouldn't show up on the list available in the VideoProducer.
>>>What would show up was the WDM driver. So, I had one of the osprey's go
>>>through that instead (set in the osprey software to set defaults if I
>>>recall correctly) and thus got all 4 cards going simultaneously. All
>>>seems fine now. So, a little tweaking involved...
>>>Now I'm ready to try 2.2 again with some of the fixes/hacks now out
>>>there....
>>>-John Q.
>>Bob Riddle (bdr at internet2.edu) Technologist,Internet2
>>3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
>>Business Phone: 734.913.4257 Fax Number: 734.913.4255
>>"Math illiteracy affects 7 out of every 5 people"
