[AG-TECH] Osprey Cards....... Desperation
John I Quebedeaux Jr
johnq at lsu.edu
Fri Aug 6 20:15:41 CDT 2004
Great. On WinXP - on the 288x352 question, I did it by using Regedit...
from a previous tip awhile back.
Bring up regedit (for me: command prompt, type regedit)
Look for: HKEY_CURRENT_USER --> Software --> Osprey --> Osprey100 -->
Device0 (you should have as many devices as cards installed 0 through
x) --> VcDll
Select VcDll and look for Width and Height. Width is 352 (or 160 in
hex) and Height is 288 (or 120 in hex).
Rinse and repeat for each card (device).
If there is another way to do this, I'd love to know. For the WDM I was
able to do it through VidCap I believe and set it to 288x352 there for
my 4th card.
-John Q.
On Aug 6, 2004, at 6:40 PM, Bob Riddle wrote:
> I'm running on WinXP with AG 2.2 with 3 Osprey cards using the VFW and
> the "script fix" - it works just fine for me. Remind me again - how
> do I fix the video to 288x352? I just ran VidCap to set the Video
> source to svideo for each of the Osprey cards.
> John I Quebedeaux Jr wrote:
>> Stuart,
>> I now have a windows xp system with 4 osprey's running with AG 2.1.2.
>> You have to go back, after the initial installation of the osprey's
>> current version of the drivers, to install the VfW version of the
>> drivers. I came across documentation to do just this with the
>> software that came with the Osprey's. This involved getting the
>> drivers, manually updating the driver to the older version for each
>> card... rinse repeat...
>> At least, this is what worked for me. Then, fix the video to 288x352,
>> s-video, etc.
>> Then, the problem I had was with 4 cards - while the osprey software
>> would see them just fine and they were all registered - but somehow
>> the 4th card wouldn't show up on the list available in the
>> VideoProducer. What would show up was the WDM driver. So, I had one
>> of the osprey's go through that instead (set in the osprey software
>> to set defaults if I recall correctly) and thus got all 4 cards going
>> simultaneously. All seems fine now. So, a little tweaking involved...
>> Now I'm ready to try 2.2 again with some of the fixes/hacks now out
>> there....
>> -John Q.
> Bob Riddle (bdr at internet2.edu) Technologist,Internet2
> 3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
> Business Phone: 734.913.4257 Fax Number: 734.913.4255
> "Math illiteracy affects 7 out of every 5 people"
