[AG-TECH] Osprey Cards....... Desperation
Bob Riddle
bdr at internet2.edu
Fri Aug 6 18:40:58 CDT 2004
I'm running on WinXP with AG 2.2 with 3 Osprey cards using the VFW and
the "script fix" - it works just fine for me. Remind me again - how do
I fix the video to 288x352? I just ran VidCap to set the Video source
to svideo for each of the Osprey cards.
John I Quebedeaux Jr wrote:
> Stuart,
> I now have a windows xp system with 4 osprey's running with AG 2.1.2.
> You have to go back, after the initial installation of the osprey's
> current version of the drivers, to install the VfW version of the
> drivers. I came across documentation to do just this with the software
> that came with the Osprey's. This involved getting the drivers,
> manually updating the driver to the older version for each card...
> rinse repeat...
> At least, this is what worked for me. Then, fix the video to 288x352,
> s-video, etc.
> Then, the problem I had was with 4 cards - while the osprey software
> would see them just fine and they were all registered - but somehow
> the 4th card wouldn't show up on the list available in the
> VideoProducer. What would show up was the WDM driver. So, I had one of
> the osprey's go through that instead (set in the osprey software to
> set defaults if I recall correctly) and thus got all 4 cards going
> simultaneously. All seems fine now. So, a little tweaking involved...
> Now I'm ready to try 2.2 again with some of the fixes/hacks now out
> there....
> -John Q.
Bob Riddle (bdr at internet2.edu) Technologist,Internet2
3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
Business Phone: 734.913.4257 Fax Number: 734.913.4255
"Math illiteracy affects 7 out of every 5 people"
