[AG-TECH] Connection failure, RH9 linux probs
Jerome
jeremy.knope at gmail.com
Wed Aug 4 10:31:15 CDT 2004
I build AGToolkit from source, following directions on a website I
found, used latest cvs of AG itself
problem is everything went ok, except now when I try to connect to the
venuserver it fails and traces back to some failure in globus it looks
like but no clue how to go about resolving the issue
the faliure:
08/04/2004 11:25:16 AM 1074896512 VenueClient VenueClient.py:700 DEBUG Enter
Venue: Invoke venue enter
08/04/2004 11:25:21 AM 1074896512 VenueClient VenueClient.py:667 ERROR SOAP
fault occurred
Traceback (most recent call last):
File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 347, in _
_call
config = self.config)
File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 187, in c
all
r.endheaders()
File "/usr/local/lib/python2.3/httplib.py", line 712, in endheaders
self._send_output()
File "/usr/local/lib/python2.3/httplib.py", line 597, in _send_output
self.send(msg)
File "/usr/local/lib/python2.3/httplib.py", line 564, in send
self.connect()
File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 1434, in co
nnect
self.sock.connect(self.host, self.port, self.io_attr)
File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 991, in con
nect
raise ex
GSITCPSocketException: globus_xio_gsi: gss_init_sec_context failed.
any help is greatly appreciated, i built from source because i get way
more frustrated trying to get rpms to work. i was able to do it fine
on OS X so was more than comfortable to try on our RH9 linux machine.
thanks
--jerome
