[AG-TECH] Connection failure, RH9 linux probs
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Aug  4 14:28:28 CDT 2004
Jerome:
We're using globus 2.4.3, which is also labeled as the "Pre-WS bundle"
on the globus software pages, and the corresponding pyGlobus.  Since the
error message references xio, it looks like you're using some later code
(which one?).  Anyway, you should have more success using the 2.4.3
versions.
Tom
Jerome wrote:
> I build AGToolkit from source, following directions on a website I
> found, used latest cvs of AG itself
> problem is everything went ok, except now when I try to connect to the
> venuserver it fails and traces back to some failure in globus it looks
> like but no clue how to go about resolving the issue
> the faliure:
> 08/04/2004 11:25:16 AM 1074896512 VenueClient     VenueClient.py:700 DEBUG Enter
> Venue: Invoke venue enter
> 08/04/2004 11:25:21 AM 1074896512 VenueClient     VenueClient.py:667 ERROR SOAP
> fault occurred
> Traceback (most recent call last):
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 347, in _
> _call
>     config = self.config)
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 187, in c
> all
>     r.endheaders()
>   File "/usr/local/lib/python2.3/httplib.py", line 712, in endheaders
>     self._send_output()
>   File "/usr/local/lib/python2.3/httplib.py", line 597, in _send_output
>     self.send(msg)
>   File "/usr/local/lib/python2.3/httplib.py", line 564, in send
>     self.connect()
>   File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 1434, in co
> nnect
>     self.sock.connect(self.host, self.port, self.io_attr)
>   File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 991, in con
> nect
>     raise ex
> GSITCPSocketException: globus_xio_gsi: gss_init_sec_context failed.
> any help is greatly appreciated, i built from source because i get way
> more frustrated trying to get rpms to work.  i was able to do it fine
> on OS X so was more than comfortable to try on our RH9 linux machine.
>  thanks
>  --jerome
