[AG-TECH] CVS assistance - I'd LIKE to be able to check out the new stuff
    Natalia Costas Lago
    natalia at cesga.es
    Tue Apr 20 05:38:23 CDT 2004
I got the same problem (optparse issue), when will the alpha version be
released??? Any date or estimation?
Natalia.
----- Original Message -----
To: "Todd Zimmerman" <toddz at sfu.ca>
Cc: "Randy Groves" <randy.groves at boeing.com>; <ag-tech at mcs.anl.gov>
Sent: Friday, April 09, 2004 6:41 PM
Subject: Re: [AG-TECH] CVS assistance - I'd LIKE to be able to check out the
new stuff
> Hi,
> CVS is changing quite often right now, so it's very difficult to work from
> that code at the moment.
> When we release an alpha, you will be able to use the included packages to
> work from cvs.
> Some of the problems you're having now may be helped by getting updated
> dependencies such as SOAPpy and pyGlobus, but you will still run into
> issues with new code that hasn't been polished up yet.
> Eric
> On Thu, 8 Apr 2004, Todd Zimmerman wrote:
> > I agree,
> > We're interested in extending some of of the service integration code;
> > however, we're not sure whether the CVS code is the latest code or
not...
> > Unfortunately I missed the last townhall - so I'm not sure if it was
> > brought up or not, but it would be nice to have current instructions on
> > running the CVS code if at all possible.
> > I've made it slightly farther than you, Randy - I installed the optik
> > module ( download at
> > http://sourceforge.net/project/showfiles.php?group_id=38019, unzip and
> > run the setup.py file like: 'python setup.py install')
> > I also installed the fpconst
> > (http://www.analytics.washington.edu/downloads/fpconst/) the same way.
> > Now I can get to a point where the VenueClient will start; however,
> > --personalNode doesn't seem to work (?) - I seem to have to start the
> > agNodeService and agServiceManager's separately.
> > I can _almost_ connect to a venue.... I can see who is connected etc,
> > but it seems to error out and no streams start etc.
> > Collaboration & Visualization Technician
> > WestGrid - www.westgrid.ca
> > IRMACS - www.irmacs.com
> > Ph. 604.268.6979
> > Todd Zimmerman - toddz at sfu.ca
> > Randy Groves wrote:
> > > OK - I'm having a problem with the CVS (this is on RH9).
> > > I've installed the binaries for wxPython, vic and rat from the 2.1.2
> > > release.
> > > I've grabbed the latest, and following the README-developer notes
(which
> > > are in need of revision), I made the 'cfg' directory, and ran:
> > > python AccessGrid/tools/CvsSetup.py --agdir AccessGrid --dst cfg
> > > (note the change - in the doc it's in 'bin')
> > > This was done as root.
> > > Then I logged in as my ag user and tried to run the VenueClient:
> > > /usr/bin/VenueClient.py --personalNode
> > > I get the following error:
> > > Traceback (most recent call last):
> > >   File "./VenueClient.py", line 38, in ?
> > >     from AccessGrid.Toolkit import WXGUIApplication
> > >   File "/usr/local/src/ag/ag-cvs/AccessGrid/AccessGrid/Toolkit.py",
line
> > > 18, in
> > >     from optparse import OptionParser, Option
> > > ImportError: No module named optparse
> > > I've done some poking around, and so far, I don't see any mention of
> > > this module.  Is there a step that I'm missing?  Should I be loading a
> > > different wxPython from CVS?
> > > I know you folks are busy, but I'd like to be able to check this out
and
> > > give what assistance I can.
> > > Thanks!!
> > > -randy
