[AG-TECH] Node Setup Wizard problems
    Mike Weaver
    weaver at er.doe.gov
    Wed Apr 14 08:50:12 CDT 2004
Yes, I've read it, but using NodeManagement.py to add the audio & video
machines using the Add Service Manager dialog doesn't work either as I
mentioned in my last post.  I attached my logs to that post, but the
agsm.log & agns.log files are empty.
Believe me, I understand how busy you guys are and I don't post for
assistance unless I've exhausted all avenues of research :)
Thanks, and I'll keep plugging away at it.
Mike
----- Original Message -----
To: "'Mike Weaver'" <weaver at er.doe.gov>; <ag-tech at mcs.anl.gov>; "'Randy
Groves'" <randy.groves at boeing.com>
Sent: Wednesday, April 14, 2004 09:29
Subject: RE: [AG-TECH] Node Setup Wizard problems
> Not to sound flippant, but have you read the existing docs?
http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/RoomBasedNo
> de-HowTo/RoomBasedNode-HowTo.html
> Looks like that is what you both want.
> --Ivan
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Mike Weaver
> > Sent: Wednesday, April 14, 2004 5:03 AM
> > To: ag-tech at mcs.anl.gov; Randy Groves
> > Subject: Re: [AG-TECH] Node Setup Wizard problems
> > Ditto!
> > From: "Randy Groves" <randy.groves at boeing.com>
> > To: <ag-tech at mcs.anl.gov>
> > Sent: Wednesday, April 14, 2004 02:21
> > > I don't remember, but aren't there instructions (or is it not
> > possible?)
> > > for setting up a multiple machine node WITHOUT the Node
> > Setup Wizard?
> > I'm
> > > running into similar problems.  Time constraints dictate
> > just getting
> > this
> > > set up - whether I use the wizard or not.
> > > -randy
> > > At 12:16 PM 4/13/2004, Thomas D. Uram wrote:
> > > >Hi Mike:
> > > >Can you try configuring your node using NodeManagement.py?  This
> > should
> > > >provide additional info about the problem you're having, possibly
> > within
> > > >NodeManagement itself, and probably in the log files (agns.log,
> > agsm.log,
> > > >AGService.log).  This way, you can get your node set up, and we
can
> > > >understand the problem that the node setup wizard is
> > running into and
> > fix it.
> > > >Let me know what happens, and send your log files along if things
> > don't
> > > >work out.
> > > >Thanks,
> > > >Tom
> > > >Mike Weaver wrote:
> > > >>I installed all prerequisites and AGTK 2.1.2 on my room node
> > (Display:
> > > >>Win2K, Audio:RHL 7.3, Video: RHL 7.3) and imported my
> > certificate to
> > all
> > > >>3 machines.   I ran AGServiceManager.py on all machines and then
> > > >>NodeSetupWizard.pyw from the (W2K) Display machine.  When it
tries
> > to
> > > >>connect to the Video Capture machine, it fails.  All systems are
> > > >>time-sync'ed and DNS-resolvable (each can ping the others).  All
> > certs
> > > >>(Globus & ANL CA and my ID) look fine on machines.
> > > >>I see the AGServiceManager running on the video machine
> > and tcpdump
> > > >>shows traffic in both directions when the display machine
attempts
> > to
> > > >>connect, but it still fails.  The agsm.log file on the
> > video machine
> > is
> > > >>empty even with the --debug option.  The agsm.log file on the
> > display
> > > >>machine is also empty.  The NodeSetupWizard.log on the Display
> > machine
> > > >>says:
> > > >>04/13/04 12:32:52 1728 AG.NodeSetupWizard
nodesetupwizard.pyw:332
> > INFO
> > > >>NodeSetupWizard:VideoCaptureWindow:Validate: Service
> > manager is not
> > > >>started
> > > >>Any advise would be appreciated.
> > > >>Mike
> > > >>Mike Weaver
> > > >>Sr. Network Administrator
> > > >>SC-31/Germantown Building
> > > >>US Department of Energy
> > > >>1000 Independence Avenue, SW
> > > >>Washington, D.C. 20585-1290
> > > >>Voice: 301-903-0072
> > > >>Fax: 301-528-2701
> > > >>Email: weaver at er.doe.gov
