[AG-TECH] Node Setup Wizard problems
    Ivan R. Judson
    judson at mcs.anl.gov
    Wed Apr 14 08:29:53 CDT 2004
Not to sound flippant, but have you read the existing docs?
http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/RoomBasedNo
de-HowTo/RoomBasedNode-HowTo.html
Looks like that is what you both want.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Mike Weaver
> Sent: Wednesday, April 14, 2004 5:03 AM
> To: ag-tech at mcs.anl.gov; Randy Groves
> Subject: Re: [AG-TECH] Node Setup Wizard problems
> Ditto!
> From: "Randy Groves" <randy.groves at boeing.com>
> To: <ag-tech at mcs.anl.gov>
> Sent: Wednesday, April 14, 2004 02:21
> > I don't remember, but aren't there instructions (or is it not
> possible?)
> > for setting up a multiple machine node WITHOUT the Node
> Setup Wizard?
> I'm
> > running into similar problems.  Time constraints dictate
> just getting
> this
> > set up - whether I use the wizard or not.
> > -randy
> > At 12:16 PM 4/13/2004, Thomas D. Uram wrote:
> > >Hi Mike:
> > >Can you try configuring your node using NodeManagement.py?  This
> should
> > >provide additional info about the problem you're having, possibly
> within
> > >NodeManagement itself, and probably in the log files (agns.log,
> agsm.log,
> > >AGService.log).  This way, you can get your node set up, and we can
> > >understand the problem that the node setup wizard is
> running into and
> fix it.
> > >Let me know what happens, and send your log files along if things
> don't
> > >work out.
> > >Thanks,
> > >Tom
> > >Mike Weaver wrote:
> > >>I installed all prerequisites and AGTK 2.1.2 on my room node
> (Display:
> > >>Win2K, Audio:RHL 7.3, Video: RHL 7.3) and imported my
> certificate to
> all
> > >>3 machines.   I ran AGServiceManager.py on all machines and then
> > >>NodeSetupWizard.pyw from the (W2K) Display machine.  When it tries
> to
> > >>connect to the Video Capture machine, it fails.  All systems are
> > >>time-sync'ed and DNS-resolvable (each can ping the others).  All
> certs
> > >>(Globus & ANL CA and my ID) look fine on machines.
> > >>I see the AGServiceManager running on the video machine
> and tcpdump
> > >>shows traffic in both directions when the display machine attempts
> to
> > >>connect, but it still fails.  The agsm.log file on the
> video machine
> is
> > >>empty even with the --debug option.  The agsm.log file on the
> display
> > >>machine is also empty.  The NodeSetupWizard.log on the Display
> machine
> > >>says:
> > >>04/13/04 12:32:52 1728 AG.NodeSetupWizard nodesetupwizard.pyw:332
> INFO
> > >>NodeSetupWizard:VideoCaptureWindow:Validate: Service
> manager is not
> > >>started
> > >>Any advise would be appreciated.
> > >>Mike
> > >>Mike Weaver
> > >>Sr. Network Administrator
> > >>SC-31/Germantown Building
> > >>US Department of Energy
> > >>1000 Independence Avenue, SW
> > >>Washington, D.C. 20585-1290
> > >>Voice: 301-903-0072
> > >>Fax: 301-528-2701
> > >>Email: weaver at er.doe.gov
