[AG-TECH] Node Setup Wizard problems
    Ivan R. Judson
    judson at mcs.anl.gov
    Wed Apr 14 08:55:40 CDT 2004
No problem; just saw the part where it was use the wizard or do it manually,
and that's the manual approach. We'll help figure out your problem and get
things working...
--Ivan
> -----Original Message-----
> From: Mike Weaver [mailto:weaver at er.doe.gov]
> Sent: Wednesday, April 14, 2004 8:50 AM
> To: judson at mcs.anl.gov; ag-tech at mcs.anl.gov; 'Randy Groves'
> Subject: Re: [AG-TECH] Node Setup Wizard problems
> Yes, I've read it, but using NodeManagement.py to add the
> audio & video machines using the Add Service Manager dialog
> doesn't work either as I mentioned in my last post.  I
> attached my logs to that post, but the agsm.log & agns.log
> files are empty.
> Believe me, I understand how busy you guys are and I don't
> post for assistance unless I've exhausted all avenues of research :)
> Thanks, and I'll keep plugging away at it.
> Mike
> From: "Ivan R. Judson" <judson at mcs.anl.gov>
> To: "'Mike Weaver'" <weaver at er.doe.gov>;
> <ag-tech at mcs.anl.gov>; "'Randy Groves'" <randy.groves at boeing.com>
> Sent: Wednesday, April 14, 2004 09:29
> Subject: RE: [AG-TECH] Node Setup Wizard problems
> > Not to sound flippant, but have you read the existing docs?
> http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentati
> on/RoomBasedNo
> > de-HowTo/RoomBasedNode-HowTo.html
> > Looks like that is what you both want.
> > --Ivan
> > > From: owner-ag-tech at mcs.anl.gov
> > > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Mike Weaver
> > > Sent: Wednesday, April 14, 2004 5:03 AM
> > > To: ag-tech at mcs.anl.gov; Randy Groves
> > > Ditto!
> > > From: "Randy Groves" <randy.groves at boeing.com>
> > > To: <ag-tech at mcs.anl.gov>
> > > Sent: Wednesday, April 14, 2004 02:21
> > > > I don't remember, but aren't there instructions (or is it not
> > > possible?)
> > > > for setting up a multiple machine node WITHOUT the Node
> > > Setup Wizard?
> > > I'm
> > > > running into similar problems.  Time constraints dictate
> > > just getting
> > > this
> > > > set up - whether I use the wizard or not.
> > > > -randy
> > > > At 12:16 PM 4/13/2004, Thomas D. Uram wrote:
> > > > >Hi Mike:
> > > > >Can you try configuring your node using
> NodeManagement.py?  This
> > > should
> > > > >provide additional info about the problem you're
> having, possibly
> > > within
> > > > >NodeManagement itself, and probably in the log files (agns.log,
> > > agsm.log,
> > > > >AGService.log).  This way, you can get your node set up, and we
> can
> > > > >understand the problem that the node setup wizard is
> > > running into and
> > > fix it.
> > > > >Let me know what happens, and send your log files
> along if things
> > > don't
> > > > >work out.
> > > > >Thanks,
> > > > >Tom
> > > > >Mike Weaver wrote:
> > > > >>I installed all prerequisites and AGTK 2.1.2 on my room node
> > > (Display:
> > > > >>Win2K, Audio:RHL 7.3, Video: RHL 7.3) and imported my
> > > certificate to
> > > all
> > > > >>3 machines.   I ran AGServiceManager.py on all
> machines and then
> > > > >>NodeSetupWizard.pyw from the (W2K) Display machine.  When it
> tries
> > > to
> > > > >>connect to the Video Capture machine, it fails.  All
> systems are
> > > > >>time-sync'ed and DNS-resolvable (each can ping the
> others).  All
> > > certs
> > > > >>(Globus & ANL CA and my ID) look fine on machines.
> > > > >>I see the AGServiceManager running on the video machine
> > > and tcpdump
> > > > >>shows traffic in both directions when the display machine
> attempts
> > > to
> > > > >>connect, but it still fails.  The agsm.log file on the
> > > video machine
> > > is
> > > > >>empty even with the --debug option.  The agsm.log file on the
> > > display
> > > > >>machine is also empty.  The NodeSetupWizard.log on the Display
> > > machine
> > > > >>says:
> > > > >>04/13/04 12:32:52 1728 AG.NodeSetupWizard
> nodesetupwizard.pyw:332
> > > INFO
> > > > >>NodeSetupWizard:VideoCaptureWindow:Validate: Service
> > > manager is not
> > > > >>started
> > > > >>Any advise would be appreciated.
> > > > >>Mike
> > > > >>Mike Weaver
> > > > >>Sr. Network Administrator
> > > > >>SC-31/Germantown Building
> > > > >>US Department of Energy
> > > > >>1000 Independence Avenue, SW
> > > > >>Washington, D.C. 20585-1290
> > > > >>Voice: 301-903-0072
> > > > >>Fax: 301-528-2701
> > > > >>Email: weaver at er.doe.gov
