[AG-TECH] Node Setup Wizard problems
    Mike Weaver
    weaver at er.doe.gov
    Wed Apr 14 05:02:50 CDT 2004
Ditto!
----- Original Message -----
To: <ag-tech at mcs.anl.gov>
Sent: Wednesday, April 14, 2004 02:21
Subject: Re: [AG-TECH] Node Setup Wizard problems
> I don't remember, but aren't there instructions (or is it not
possible?)
> for setting up a multiple machine node WITHOUT the Node Setup Wizard?
I'm
> running into similar problems.  Time constraints dictate just getting
this
> set up - whether I use the wizard or not.
> -randy
> At 12:16 PM 4/13/2004, Thomas D. Uram wrote:
> >Hi Mike:
> >Can you try configuring your node using NodeManagement.py?  This
should
> >provide additional info about the problem you're having, possibly
within
> >NodeManagement itself, and probably in the log files (agns.log,
agsm.log,
> >AGService.log).  This way, you can get your node set up, and we can
> >understand the problem that the node setup wizard is running into and
fix it.
> >Let me know what happens, and send your log files along if things
don't
> >work out.
> >Thanks,
> >Tom
> >Mike Weaver wrote:
> >>I installed all prerequisites and AGTK 2.1.2 on my room node
(Display:
> >>Win2K, Audio:RHL 7.3, Video: RHL 7.3) and imported my certificate to
all
> >>3 machines.   I ran AGServiceManager.py on all machines and then
> >>NodeSetupWizard.pyw from the (W2K) Display machine.  When it tries
to
> >>connect to the Video Capture machine, it fails.  All systems are
> >>time-sync'ed and DNS-resolvable (each can ping the others).  All
certs
> >>(Globus & ANL CA and my ID) look fine on machines.
> >>I see the AGServiceManager running on the video machine and tcpdump
> >>shows traffic in both directions when the display machine attempts
to
> >>connect, but it still fails.  The agsm.log file on the video machine
is
> >>empty even with the --debug option.  The agsm.log file on the
display
> >>machine is also empty.  The NodeSetupWizard.log on the Display
machine
> >>says:
> >>04/13/04 12:32:52 1728 AG.NodeSetupWizard nodesetupwizard.pyw:332
INFO
> >>NodeSetupWizard:VideoCaptureWindow:Validate: Service manager is not
> >>started
> >>Any advise would be appreciated.
> >>Mike
> >>Mike Weaver
> >>Sr. Network Administrator
> >>SC-31/Germantown Building
> >>US Department of Energy
> >>1000 Independence Avenue, SW
> >>Washington, D.C. 20585-1290
> >>Voice: 301-903-0072
> >>Fax: 301-528-2701
> >>Email: weaver at er.doe.gov
