[AG-TECH] New Shared Image tool
sheetal
spatil at iupui.edu
Mon Apr 12 16:16:55 CDT 2004
Hi Dave,
The tool works great!!!
When I installed it for the 1st time, I got some errors. I did a re-install
and it worked fine.
AGSharedObject: initialize with url = https://vv2.mcs.anl.gov:9000/213
AGSharedObject: Getting application proxy
AGSharedObject: join application
AGSharedObject: get data channel
AGSharedObject: connected and event channel started
Registering event NewImage :
Registering event NewMarks :
looking for data: ImageFile
looking for data: MarkupData
Loading image: Water lilies.jpg
Traceback (most recent call last):
File "AGBasicImage.py", line 427, in ?
app = MyApp(0)
File "C:\Python22\Lib\site-packages\wxPython\wx.py", line 1957, in
__init__
_wxStart(self.OnInit)
File "AGBasicImage.py", line 422, in OnInit
frame = ImageFrame(None,-1)
File "AGBasicImage.py", line 316, in __init__
localImageFile = self.AG.DownloadFile(animage)
File "AGBasicImage.py", line 137, in DownloadFile
self.dataStoreClient.LoadData()
File "C:\Python22\Lib\site-packages\AccessGrid\DataStoreClient.py", line
232
in LoadData
descList = self.datastoreProxy.GetDataDescriptions()
File
"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py
line 3660, in __call__
return self.__r_call(*args, **kw)
File
line 3680, in __r_call
self.__hd, self.__ma)
File
line 3580, in __call
config = self.config)
File
"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\Client.py",
ne 188, in call
r.endheaders()
File "C:\Python22\lib\httplib.py", line 695, in endheaders
self._send_output()
File "C:\Python22\lib\httplib.py", line 581, in _send_output
self.send(msg)
File "C:\Python22\lib\httplib.py", line 548, in send
self.connect()
File
"C:\Software\AccessGrid\AccessGrid\dist\Lib\site-packages\pyGlobus\io.p
, line 1084, in connect
File
, line 663, in connect
pyGlobus.io.GSITCPSocketException: a system call failed (Unknown error)
Sheetal
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of George Estes
Sent: Monday, April 12, 2004 2:38 PM
To: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] New Shared Image tool
Don't know why but just coping the file did not work for me. I had to go
through the install process and it worked. Anyway, pretty cool but it
needs an undo command.
George
At 10:18 AM 4/12/2004 -0500, you wrote:
>X-Envelope-From: semeraro at ncsa.uiuc.edu
>X-Envelope-To: <ag-tech at mcs.anl.gov>
>X-Sender: semeraro at mail.ncsa.uiuc.edu (Unverified)
>X-Mailer: QUALCOMM Windows Eudora Version 5.1
>Date: Mon, 12 Apr 2004 10:18:40 -0500
>From: Dave Semeraro <semeraro at ncsa.uiuc.edu>
>Subject: [AG-TECH] New Shared Image tool
>X-Spam-Status: No, hits=0.0 required=5.0
> tests=none
> version=2.55
>X-Spam-Level:
>X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
>Sender: owner-ag-tech at mcs.anl.gov
>X-Deliver-To: gestes
>X-MD5SUM: a6100c44149c7bd740c8dea5b3b15891
>Hello folks,
>I finally finished adding markup capability to the shared image viewer.
That means that once
>an image is loaded you can use the mouse and left mouse button to draw on
the image
>with a pen. Click the left mouse button and hold it down while you draw on
the image. When
>you release the left button the coordinates of what you drew are uploaded
to the venue and
>all the other image viewers are updated. You will just see the image change
to include the
>marks made by the user. The marks do not show up incrementally. Hey it was
the easiest
>implementation.
>I also added the capability to change pen color. This is handy when others
are marking on
