[AG-TECH] New Shared Image tool
    Dave Semeraro
    semeraro at ncsa.uiuc.edu
    Tue Apr 13 09:08:49 CDT 2004
Glad you like the new tool. I am not sure what the stream of errors you
have in your mail
means. It looks like it is having problems getting the image from the venue
server. But since
you reinstalled and it works I guess it is just one of those AG mysteries.
At 04:16 PM 4/12/2004 -0500, sheetal wrote:
>Hi Dave,
>The tool works great!!!
>When I installed it for the 1st time, I got some errors. I did a re-install
>and it worked fine.
>AGSharedObject: initialize with url = https://vv2.mcs.anl.gov:9000/213
>AGSharedObject: Getting application proxy
>AGSharedObject: join application
>AGSharedObject: get data channel
>AGSharedObject: connected and event channel started
>Registering event NewImage :
>Registering event NewMarks :
>looking for data: ImageFile
>looking for data: MarkupData
>Loading image:  Water lilies.jpg
>Traceback (most recent call last):
>   File "AGBasicImage.py", line 427, in ?
>     app = MyApp(0)
>   File "C:\Python22\Lib\site-packages\wxPython\wx.py", line 1957, in
>__init__
>     _wxStart(self.OnInit)
>   File "AGBasicImage.py", line 422, in OnInit
>     frame = ImageFrame(None,-1)
>   File "AGBasicImage.py", line 316, in __init__
>     localImageFile = self.AG.DownloadFile(animage)
>   File "AGBasicImage.py", line 137, in DownloadFile
>     self.dataStoreClient.LoadData()
>   File "C:\Python22\Lib\site-packages\AccessGrid\DataStoreClient.py", line
>232
>in LoadData
>     descList = self.datastoreProxy.GetDataDescriptions()
>   File
>"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py
>  line 3660, in __call__
>     return self.__r_call(*args, **kw)
>   File
>  line 3680, in __r_call
>     self.__hd, self.__ma)
>   File
>  line 3580, in __call
>     config = self.config)
>   File
>"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\Client.py",
>ne 188, in call
>     r.endheaders()
>   File "C:\Python22\lib\httplib.py", line 695, in endheaders
>     self._send_output()
>   File "C:\Python22\lib\httplib.py", line 581, in _send_output
>     self.send(msg)
>   File "C:\Python22\lib\httplib.py", line 548, in send
>     self.connect()
>   File
>"C:\Software\AccessGrid\AccessGrid\dist\Lib\site-packages\pyGlobus\io.p
>, line 1084, in connect
>   File
>, line 663, in connect
>pyGlobus.io.GSITCPSocketException: a system call failed (Unknown error)
>Regards,
>Sheetal
>-----Original Message-----
>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
>Of George Estes
>Sent: Monday, April 12, 2004 2:38 PM
>To: ag-tech at mcs.anl.gov
>Subject: Re: [AG-TECH] New Shared Image tool
>   Don't know why but just coping the file did not work for me.  I had to go
>through the install process and it worked.   Anyway, pretty cool but it
>needs an undo command.
>George
>At 10:18 AM 4/12/2004 -0500, you wrote:
> >X-Envelope-From: semeraro at ncsa.uiuc.edu
> >X-Envelope-To: <ag-tech at mcs.anl.gov>
> >X-Sender: semeraro at mail.ncsa.uiuc.edu (Unverified)
> >X-Mailer: QUALCOMM Windows Eudora Version 5.1
> >Date: Mon, 12 Apr 2004 10:18:40 -0500
> >From: Dave Semeraro <semeraro at ncsa.uiuc.edu>
> >Subject: [AG-TECH] New Shared Image tool
> >X-Spam-Status: No, hits=0.0 required=5.0
> >        tests=none
> >        version=2.55
> >X-Spam-Level:
> >X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
> >Sender: owner-ag-tech at mcs.anl.gov
> >X-Deliver-To: gestes
> >X-MD5SUM: a6100c44149c7bd740c8dea5b3b15891
> >Hello folks,
> >I finally finished adding markup capability to the shared image viewer.
>That means that once
> >an image is loaded you can use the mouse and left mouse button to draw on
>the image
> >with a pen. Click the left mouse button and hold it down while you draw on
>the image. When
> >you release the left button the coordinates of what you drew are uploaded
>to the venue and
> >all the other image viewers are updated. You will just see the image change
>to include the
> >marks made by the user. The marks do not show up incrementally. Hey it was
>the easiest
> >implementation.
> >I also added the capability to change pen color. This is handy when others
>are marking on
Dave Semeraro Ph.D.
Visualization and Virtual Environments Group
NCSA University of Illinois
605 E. Springfield Ave.
Champaign, IL 61820
Semeraro at ncsa.uiuc.edu
(217) 244-1852
