[AG-TECH] Problems starting up AG on RH9 on Nvidia - any solutions?
Randy Groves
randy.groves at boeing.com
Wed Apr 7 16:17:21 CDT 2004
(Killed by the time-warp again ...)
I realized almost immediately after I sent this message that I forgot that
I was VNC'd into this box, and sent another note indicating so, and that
this worked fine on the console of the machine. Andrew Swan put me on the
path of a solution. He suggested checking the display setting with
xdpyinfo. Upon doing so in the VNC session, I found that the default
setting of vncserver of 8 bits of display depth is too small for the
vic. I altered the vncserver so that it used 16 bits on startup, and I can
now run the client over VNC.
Just in case anyone else has hit this ...
At 01:15 PM 4/7/2004, Joshua M. Brown wrote:
> > What's going on here? Anybody gotten this Nvidia card to work in RH9? I
> > should also add that I've not added any special Nvidia drivers to this
> > machine. Just using whatever got loaded with RH9.
>i don't know if this can fix your problem for you or not, but yes, nvidia
>provides an excellent pack of drivers for linux. If they do not have one
>prebuilt for you, the package will compile a new driver for your machine.
>You'll need to visit the site and grab the latest. Gotta love nvidia.
>i have a dual head nvidia on RH9 at home...the x86config file took some
>tweaking though. i strongly suggest *always* backing up your config file
>before making any changes.
>josh
> > Thanks!!
> > -randy
