[AG-TECH] Problem Managing Node
    Mike Weaver
    weaver at er.doe.gov
    Wed Apr  7 11:14:03 CDT 2004
Hi all,
I just built AG2 on a Fedora Core system using University of
Queensland's RPMs.  Got my Identity certificate and brought up the
VenueClient.  This worked fine.  When I go to Node Management and enter
the default URL which resolves to https://localhost:12000/NodeService, I
get "Can not open node service management based on the URL you
specified".
AGNodeService.py, AGServiceManager.py & VenueClient.py are all running,
seemingly successfully.  I've attached the agns.log and VenueClient.log
from a debug session.  I don't see anything too unusual.  I see the code
to raise an exception in AGNodeService.py, but don't know why it's being
raised.
Might this be a certificate problem?  I originally requested a new
certificate using the AGTk while running as root.  When I fired up the
VenueClient in presonalNode mode (simplest for now, I have other
machines, but one thing at a time), it complained that it wanted to be
run by an ordinary user.  Running as a user didn't see the original cert
request, so I ran certmgr.py as root and exported the id cert and used
the VenueClient to import it.  This seemed successful.  The one thing
that I notice is running certmgr.py as either root or an ordinary user
(or even accessing the certs from the VenueClient), I don't see any CA
certs listed.  Is this correct?  Should I not have installed the AG
packages as root?  Something else?
Any advice, would be appreciated,
Mike
Mike Weaver
Sr. Network Administrator
SC-31/Germantown Building
US Department of Energy
1000 Independence Avenue, SW
Washington, D.C. 20585-1290
Voice: 301-903-0072
Fax: 301-528-2701
Email: weaver at er.doe.gov
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040407/4fb79a27/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040407/4fb79a27/attachment-0001.obj>
