[AG-TECH] re RedHat 9
Michael daley
Mike.W.Daley at cs.cardiff.ac.uk
Fri Sep 26 08:42:40 CDT 2003
Hi
I've just successfull install teh AG under readhat 9. I had a similar
problem but found that if you do everything in the following order it works
install wxPythonGTK
unpack AccessGrid-2.1-3.tar
in the directory where AG installs is a file called pyOpenSSL_AG.rpm
install this file next at some point it will ask for the second RedHat disk.
Once it has finished run the install.sh file in the AG directory
Mike.
