[AG-TECH] Node Management - configuring video streams
Rabarison Monika Klara
monika.k.rabarison at ccaix.jsums.edu
Tue Sep 9 14:49:05 CDT 2003
It works great. Thank you,
Monika
On Tue, 9 Sep 2003, Thomas D. Uram wrote:
> This is a known problem with the video producer. A fixed video producer
> service package is available at:
> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.1.1/patch/VideoProducerService.zip
> This file should be placed as is in the directory that holds services,
> on the machine running the NodeService (the display machine in
> multi-machine nodes):
> Windows: InstallDir\services
> Linux: /usr/share/AccessGrid/services
> With this in place, you should get a pulldown menu for the port when
> configuring a video producer service, and vic should use that port
> correctly. The practical effect of this problem is blue streams, or
> black/white streams.
> We will be issuing a bug-fix release soon, when it's ready and
> well-tested, which will include this fix and others reported against the
> last release (2.1.1 and its variants).
> Tom
> Jason Hill wrote:
> > I was wondering if anyone else had problems setting the port for their
> > video streams. As a default the Node Manager uses Composite -
> > resulting in a black and white video stream. (I'm running a dual linux
> > operation capture and display)
> > Under the menu heading in the Node Manager, Service -> Configure there
> > is a field for port and I have tried entering the port (there is no
> > drop-down menu) and this has no effect. If no one else has had a
> > problem like this I'll file a bugzilla report - just wanted to check
> > with the community for a possible solution first.
> > Thanks,
> > -Jason
Monika Rabarison
Systems Administrator
Office of Information Technology/HPCVI
Jackson State University
Office:(601)979-5933
SciVis Lab:(601)979-1061
JSUvisNode:(601)979-1056
