[AG-TECH] Node Management - configuring video streams
Brian Corrie
brian.corrie at newmic.com
Mon Sep 8 16:25:46 CDT 2003
We have a similar problem, as we are using s-video in to the video capture
card. The odd thing is that the port settings worked in one of the earlier
versions (I think)... (2.1?).
Brian
> -----Original Message-----
> From: Jason Hill [mailto:jahill at scl.ameslab.gov]
> Sent: Monday, September 08, 2003 1:52 PM
> To: ag-tech
> Subject: [AG-TECH] Node Management - configuring video streams
> I was wondering if anyone else had problems setting the port
> for their
> video streams. As a default the Node Manager uses Composite -
> resulting
> in a black and white video stream. (I'm running a dual linux
> operation
> capture and display)
> Under the menu heading in the Node Manager, Service ->
> Configure there
> is a field for port and I have tried entering the port (there is no
> drop-down menu) and this has no effect. If no one else has
> had a problem
> like this I'll file a bugzilla report - just wanted to check with the
> community for a possible solution first.
> Thanks,
> -Jason
> Jason Hill
> Scalable Computing Laboratory, Ames Laboratory
> 310 Wilhelm Hall
> Ames, IA 50010
