[AG-TECH] Node Management - configuring video streams
Thomas D. Uram
turam at mcs.anl.gov
Tue Sep 9 13:54:17 CDT 2003
This is a known problem with the video producer. A fixed video producer
service package is available at:
http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.1.1/patch/VideoProducerService.zip
This file should be placed as is in the directory that holds services,
on the machine running the NodeService (the display machine in
multi-machine nodes):
Windows: InstallDir\services
Linux: /usr/share/AccessGrid/services
With this in place, you should get a pulldown menu for the port when
configuring a video producer service, and vic should use that port
correctly. The practical effect of this problem is blue streams, or
black/white streams.
We will be issuing a bug-fix release soon, when it's ready and
well-tested, which will include this fix and others reported against the
last release (2.1.1 and its variants).
Tom
Jason Hill wrote:
> I was wondering if anyone else had problems setting the port for their
> video streams. As a default the Node Manager uses Composite -
> resulting in a black and white video stream. (I'm running a dual linux
> operation capture and display)
> Under the menu heading in the Node Manager, Service -> Configure there
> is a field for port and I have tried entering the port (there is no
> drop-down menu) and this has no effect. If no one else has had a
> problem like this I'll file a bugzilla report - just wanted to check
> with the community for a possible solution first.
> Thanks,
> -Jason
