[AG-TECH] Node Management - configuring video streams
Eric Olson
eolson at mcs.anl.gov
Mon Sep 8 16:31:46 CDT 2003
Hi Brian and Jason,
Tom recently found and fixed a bug where some video configuration settings
(such as port) did not get set. If you need it right away, we can get you
an updated VideoProducerService.zip file, but we're working on getting
various bug fixes compiled together and released.
Eric
On Mon, 8 Sep 2003, Brian Corrie wrote:
> We have a similar problem, as we are using s-video in to the video capture
> card. The odd thing is that the port settings worked in one of the earlier
> versions (I think)... (2.1?).
> Brian
> > -----Original Message-----
> > From: Jason Hill [mailto:jahill at scl.ameslab.gov]
> > Sent: Monday, September 08, 2003 1:52 PM
> > To: ag-tech
> > Subject: [AG-TECH] Node Management - configuring video streams
> > I was wondering if anyone else had problems setting the port
> > for their
> > video streams. As a default the Node Manager uses Composite -
> > resulting
> > in a black and white video stream. (I'm running a dual linux
> > operation
> > capture and display)
> > Under the menu heading in the Node Manager, Service ->
> > Configure there
> > is a field for port and I have tried entering the port (there is no
> > drop-down menu) and this has no effect. If no one else has
> > had a problem
> > like this I'll file a bugzilla report - just wanted to check with the
> > community for a possible solution first.
> > Thanks,
> > -Jason
> > Jason Hill
> > Scalable Computing Laboratory, Ames Laboratory
> > 310 Wilhelm Hall
> > Ames, IA 50010
