[AG-TECH] multicast TALE OF WOE
Grzesiek Sedek
grzesiek at mi2.hr
Sun Sep 7 14:15:16 CDT 2003
First thing you should check is that your firewall accepts ALL traffic (
well UDP should be enough) on class D network (multicast range)
You can see very often that by default firewalls drop all incoming
traffic ( including multicast) but allow everything out.
That would explain why others can see you.
Hope that helps.
Grzesiek
On Thu, 2003-09-04 at 23:02, Stephen Bosch wrote:
> Hi, everybody:
> Okay -- I admit, this multicast stuff is Hungarian to me. I've installed
> mtrace, the kernel is configured for multicast, I'm supposed to be on a
> multicast-enabled network, but when I run the NLANR beacon, it looks
> like other sites can see me, but I am receiving nothing from them; this
> is clearly not a beacon problem, as AccessGrid stuff is not working
> either. At Todd Zimmerman's advice I tried to connect directly to
> NewMIC's venue, but got nothing.
> I've included some diagnostic output below to help in identifying the
> problem:
> root at accessgrid:/usr/src/linux-2.4.20# mtrace beaconserver.accessgrid.org
> mtrace: WARNING: no multicast group specified, so no statistics printed
> Mtrace from 140.221.9.160 to 206.75.91.40 via group 0.0.0.0
> Querying full reverse path... * switching to hop-by-hop:
> 0 accessgrid.netera.ca (206.75.91.40)
> -1 host206-75-91-33.netera.ca (206.75.91.33) PIM/BGP4+ thresh^ 0
> -2 * * * c4-van01.canet4.net (205.189.32.198) PIM thresh^ 1
> -3 * * c4-win01.canet4.net (205.189.32.2) PIM thresh^ 1
> -4 * * c4-mren.canet4.net (205.189.32.69) PIM/BGP4+ thresh^ 0
> -5 * * anl-mren-gige.anchor.anl.gov (192.5.170.213) PIM thresh^ 0
> -6 * * stardust-guava.anchor.anl.gov (130.202.222.73) PIM thresh^ 0
> -7 ag-tech.mcs.anl.gov (140.221.9.160)
> Round trip time 80 ms; total ttl of 6 required.
> COMMENT Seems to work only as far as our router.
> root at accessgrid:~# mtrace beaconserver.accessgrid.org 206.75.91.40
> 233.2.171.1
> Mtrace from 140.221.9.160 to 206.75.91.40 via group 233.2.171.1
> -1 host206-75-91-33.netera.ca (206.75.91.33) PIM thresh^ 0 Reached
> RP/Core
> Round trip time 1 ms; total ttl of 1 required.
> Waiting to accumulate statistics...Results after 10 seconds:
> Source Response Dest Overall Packet Statistics For
> Traffic From
> * * * 224.0.1.32 Packet 140.221.9.160 To 233.2.171.1
> v __/ rtt 1 ms Rate Lost/Sent = Pct Rate
> 206.75.91.33 host206-75-91-33.netera.ca Reached RP/Core
> v \__ ttl 2 0 pps ?/0 0 pps
> 206.75.91.40 206.75.91.40
> Receiver Query Source
> COMMENT: We are not receiving anything :)
> root at accessgrid:~# mtrace ag.triumf.ca 206.75.91.40 233.2.171.1
> Mtrace from 142.90.97.14 to 206.75.91.40 via group 233.2.171.1
> RP/Core
> Traffic From
> * * * 224.0.1.32 Packet 142.90.97.14 To 233.2.171.1
> root at accessgrid:~# mtrace cluster.vislab.usyd.edu.au 206.75.91.40
> 233.2.171.1
> Mtrace from 129.78.157.79 to 206.75.91.40 via group 233.2.171.1
> RP/Core
> Traffic From
> * * * 224.0.1.32 Packet 129.78.157.79 To 233.2.171.1
> eth1 Link encap:Ethernet HWaddr 00:07:E9:18:CA:CA
> inet addr:206.75.91.40 Bcast:206.75.91.47 Mask:255.255.255.240
> UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
> RX packets:167845 errors:0 dropped:0 overruns:0 frame:0
> TX packets:1656033 errors:389 dropped:0 overruns:0 carrier:389
> collisions:57357 txqueuelen:100
> RX bytes:229841872 (219.1 Mb) TX bytes:177592616 (169.3 Mb)
> Interrupt:19 Base address:0x2080 Memory:e8120000-e8140000
> root at accessgrid:~# route
> Kernel IP routing table
> Destination Gateway Genmask Flags Metric Ref Use
> Iface
> 206.75.91.32 * 255.255.255.240 U 0 0 0 eth1
> 206.75.91.0 * 255.255.255.0 U 0 0 0 eth1
> localnet * 255.255.255.0 U 0 0 0 eth0
> loopback * 255.0.0.0 U 0 0 0 lo
> 224.0.0.0 * 240.0.0.0 U 0 0 0 eth1
> default host136-159-94- 0.0.0.0 UG 0 0 0 eth0
> Anything here that looks suspicious? Note -- we get these results even
> when our non-multicast interface is disabled.
> So -- is the problem on our machine, or is it a multicast routing problem?
> Thanks for any help you can provide.
> -Stephen-
Grzesiek Sedek <grzesiek at mi2.hr>
