[AG-TECH] multicast TALE OF WOE
Stephen Bosch
sfbosch at netera.ca
Thu Sep 4 17:02:51 CDT 2003
Hi, everybody:
Okay -- I admit, this multicast stuff is Hungarian to me. I've installed
mtrace, the kernel is configured for multicast, I'm supposed to be on a
multicast-enabled network, but when I run the NLANR beacon, it looks
like other sites can see me, but I am receiving nothing from them; this
is clearly not a beacon problem, as AccessGrid stuff is not working
either. At Todd Zimmerman's advice I tried to connect directly to
NewMIC's venue, but got nothing.
I've included some diagnostic output below to help in identifying the
problem:
root at accessgrid:/usr/src/linux-2.4.20# mtrace beaconserver.accessgrid.org
mtrace: WARNING: no multicast group specified, so no statistics printed
Mtrace from 140.221.9.160 to 206.75.91.40 via group 0.0.0.0
Querying full reverse path... * switching to hop-by-hop:
0 accessgrid.netera.ca (206.75.91.40)
-1 host206-75-91-33.netera.ca (206.75.91.33) PIM/BGP4+ thresh^ 0
-2 * * * c4-van01.canet4.net (205.189.32.198) PIM thresh^ 1
-3 * * c4-win01.canet4.net (205.189.32.2) PIM thresh^ 1
-4 * * c4-mren.canet4.net (205.189.32.69) PIM/BGP4+ thresh^ 0
-5 * * anl-mren-gige.anchor.anl.gov (192.5.170.213) PIM thresh^ 0
-6 * * stardust-guava.anchor.anl.gov (130.202.222.73) PIM thresh^ 0
-7 ag-tech.mcs.anl.gov (140.221.9.160)
Round trip time 80 ms; total ttl of 6 required.
COMMENT Seems to work only as far as our router.
root at accessgrid:~# mtrace beaconserver.accessgrid.org 206.75.91.40
233.2.171.1
Mtrace from 140.221.9.160 to 206.75.91.40 via group 233.2.171.1
-1 host206-75-91-33.netera.ca (206.75.91.33) PIM thresh^ 0 Reached
RP/Core
Round trip time 1 ms; total ttl of 1 required.
Waiting to accumulate statistics...Results after 10 seconds:
Source Response Dest Overall Packet Statistics For
Traffic From
* * * 224.0.1.32 Packet 140.221.9.160 To 233.2.171.1
v __/ rtt 1 ms Rate Lost/Sent = Pct Rate
206.75.91.33 host206-75-91-33.netera.ca Reached RP/Core
v \__ ttl 2 0 pps ?/0 0 pps
206.75.91.40 206.75.91.40
Receiver Query Source
COMMENT: We are not receiving anything :)
root at accessgrid:~# mtrace ag.triumf.ca 206.75.91.40 233.2.171.1
Mtrace from 142.90.97.14 to 206.75.91.40 via group 233.2.171.1
RP/Core
Traffic From
* * * 224.0.1.32 Packet 142.90.97.14 To 233.2.171.1
root at accessgrid:~# mtrace cluster.vislab.usyd.edu.au 206.75.91.40
233.2.171.1
Mtrace from 129.78.157.79 to 206.75.91.40 via group 233.2.171.1
RP/Core
Traffic From
* * * 224.0.1.32 Packet 129.78.157.79 To 233.2.171.1
eth1 Link encap:Ethernet HWaddr 00:07:E9:18:CA:CA
inet addr:206.75.91.40 Bcast:206.75.91.47 Mask:255.255.255.240
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:167845 errors:0 dropped:0 overruns:0 frame:0
TX packets:1656033 errors:389 dropped:0 overruns:0 carrier:389
collisions:57357 txqueuelen:100
RX bytes:229841872 (219.1 Mb) TX bytes:177592616 (169.3 Mb)
Interrupt:19 Base address:0x2080 Memory:e8120000-e8140000
root at accessgrid:~# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use
Iface
206.75.91.32 * 255.255.255.240 U 0 0 0 eth1
206.75.91.0 * 255.255.255.0 U 0 0 0 eth1
localnet * 255.255.255.0 U 0 0 0 eth0
loopback * 255.0.0.0 U 0 0 0 lo
224.0.0.0 * 240.0.0.0 U 0 0 0 eth1
default host136-159-94- 0.0.0.0 UG 0 0 0 eth0
Anything here that looks suspicious? Note -- we get these results even
when our non-multicast interface is disabled.
So -- is the problem on our machine, or is it a multicast routing problem?
Thanks for any help you can provide.
-Stephen-
Stephen Bosch
Collaborative Systems Specialist
Netera Alliance Inc.
Biosciences 530B
2500 University Dr NW
Calgary AB T2N 1N4
tel (403) 220 2546
fax (403) 282 0838
