[AG-TECH] AG2.1.1b multi-machine node problems
Michael Daw
mike.daw at man.ac.uk
Fri Sep 5 11:02:10 CDT 2003
Thanks, George. I did try this when I encountered the problem. I've just
tried it again to make sure, but it doesn't work for me!
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of George Estes
> Sent: 05 September 2003 15:10
> To: Michael Daw
> Cc: ag Tech
> Subject: Re: [AG-TECH] AG2.1.1b multi-machine node problems
> Mike,
> Sounds like you're encountering the install as administrator, run as
> user problem. If this is on a windows machine, you're having the same
> problem I had. This is what I did to make it work, install as user with
> administrator privileges and change the "start in" path in the
> venue client
> shortcut to C:\Program Files\Access Grid Toolkit\bin. The Node Setup
> Wizard was then able to find the services.
> Hope this works for you.
> George
> At 11:10 AM 9/5/2003 +0100, you wrote:
> >Has anyone found any problems configuring a AG2.1.1 multi-machine node?
> >I get to the stage where I can add the ServiceManagers, but I can't add
> >associated Services (the dialog is blank). I've tried the Node
> Setup Wizard
> >and this fails too (when I press 'Finish', it flags an error and sends an
> >automated log to ANL).
> >Alternatively, has anyone done this successfully? Or - best of all - has
> >anyone encountered this problem and overcome it?
> >Frustratingly enough, I managed to do this under AG2.0, but there was the
> >(now fixed) bug of no support for PAL. So, something's changed...
> >--Mike
> >_______________________________________________________
> >Michael Daw, e-Science Consultant
> >SVE Group (Supercomputing, Visualization and e-Science)
> >Manchester Computing, Kilburn Building,
> >University of Manchester, Manchester M13 9PL, UK
> >Tel: +44 (0)161 275 7026
> >Fax: +44 (0)161 275 6800
> >Email: michael.daw at man.ac.uk
> >http://www.sve.man.ac.uk/General/Staff/daw
