[AG-TECH] AG2.1.1b multi-machine node problems
Ivan R. Judson
judson at mcs.anl.gov
Fri Sep 5 11:42:55 CDT 2003
Mike,
Another solution that has worked for us is to run the globus configuration
wizard as the user using the AGTk (admin or not). After having installed as
the admin, this will initialize the user environment -- making it possible
to use the toolkit as a non-admin user.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Michael Daw
> Sent: Friday, September 05, 2003 11:02 AM
> To: George Estes
> Cc: ag Tech
> Subject: RE: [AG-TECH] AG2.1.1b multi-machine node problems
> Thanks, George. I did try this when I encountered the
> problem. I've just tried it again to make sure, but it
> doesn't work for me!
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> > Behalf Of George Estes
> > Sent: 05 September 2003 15:10
> > To: Michael Daw
> > Cc: ag Tech
> > Subject: Re: [AG-TECH] AG2.1.1b multi-machine node problems
> > Mike,
> > Sounds like you're encountering the install as
> administrator, run
> > as user problem. If this is on a windows machine, you're
> having the
> > same problem I had. This is what I did to make it work, install as
> > user with administrator privileges and change the "start
> in" path in
> > the venue client shortcut to C:\Program Files\Access Grid
> Toolkit\bin.
> > The Node Setup Wizard was then able to find the services.
> > Hope this works for you.
> > George
> > At 11:10 AM 9/5/2003 +0100, you wrote:
> > >Has anyone found any problems configuring a AG2.1.1 multi-machine
> > >node?
> > >I get to the stage where I can add the ServiceManagers,
> but I can't
> > >add associated Services (the dialog is blank). I've tried the Node
> > Setup Wizard
> > >and this fails too (when I press 'Finish', it flags an error and
> > >sends an automated log to ANL).
> > >Alternatively, has anyone done this successfully? Or -
> best of all -
> > >has anyone encountered this problem and overcome it?
> > >Frustratingly enough, I managed to do this under AG2.0,
> but there was
> > >the (now fixed) bug of no support for PAL. So, something's
> changed...
> > >--Mike
> > >_______________________________________________________
> > >Michael Daw, e-Science Consultant
> > >SVE Group (Supercomputing, Visualization and e-Science)
> > >Manchester Computing, Kilburn Building,
> > >University of Manchester, Manchester M13 9PL, UK
> > >Tel: +44 (0)161 275 7026
> > >Fax: +44 (0)161 275 6800
> > >Email: michael.daw at man.ac.uk
> > >http://www.sve.man.ac.uk/General/Staff/daw
