[AG-TECH] AG2.1.1b multi-machine node problems
George Estes
gestes at ncsa.uiuc.edu
Fri Sep 5 09:09:30 CDT 2003
Mike,
Sounds like you're encountering the install as administrator, run as
user problem. If this is on a windows machine, you're having the same
problem I had. This is what I did to make it work, install as user with
administrator privileges and change the "start in" path in the venue client
shortcut to C:\Program Files\Access Grid Toolkit\bin. The Node Setup
Wizard was then able to find the services.
Hope this works for you.
George
At 11:10 AM 9/5/2003 +0100, you wrote:
>Has anyone found any problems configuring a AG2.1.1 multi-machine node?
>I get to the stage where I can add the ServiceManagers, but I can't add
>associated Services (the dialog is blank). I've tried the Node Setup Wizard
>and this fails too (when I press 'Finish', it flags an error and sends an
>automated log to ANL).
>Alternatively, has anyone done this successfully? Or - best of all - has
>anyone encountered this problem and overcome it?
>Frustratingly enough, I managed to do this under AG2.0, but there was the
>(now fixed) bug of no support for PAL. So, something's changed...
>--Mike
>_______________________________________________________
>Michael Daw, e-Science Consultant
>SVE Group (Supercomputing, Visualization and e-Science)
>Manchester Computing, Kilburn Building,
>University of Manchester, Manchester M13 9PL, UK
>Tel: +44 (0)161 275 7026
>Fax: +44 (0)161 275 6800
>Email: michael.daw at man.ac.uk
>http://www.sve.man.ac.uk/General/Staff/daw
