[AG-TECH] How to transfer a certificate
Robert Olson
olson at mcs.anl.gov
Thu Oct 16 09:04:51 CDT 2003
In 2.1.1b you'll have to download certmgr.py from the CVS repo:
http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/*checkout*/AccessGrid/bin/certmgr.py?rev=1.4
(or http://snurl.com/2p00 )
and drop it into /Program Files/Access Grid Toolkit/bin.
Then you can run:
C:\>"\Program Files\Access Grid Toolkit\bin\certmgr.py"
(ID mode) > list
1. (Default) /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Bob Olson
(ID mode) > export 1 c:\temp\mycert.pem
Export certificate /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Bob Olson to
c:\temp\mycert.pem
(ID mode) > quit
The list command shows the certs loaded. Export writes the given
certificate number out to a file. You can then copy that file to your other
computer, and do an import from the Preferences->Manage Certificates->View
Identity Certificates window to load the certificate.
--bob
At 10:29 AM 10/16/2003 -0200, Rogerio Luiz Iope wrote:
>Hi,
>I have just installed the AccessGrid Toolkit 2.1.1b
>on a Windows 2000 Server, but I am experiencing
>problems with the VideoProducer service: sometimes it freezes
>the images captured by the cameras, sometimes it even refuses
>on opening the captured windows images.
>So I decided to build another machine, a dual Xeon with Win XP.
>My question is, is it possible to transfer the Globus certificate
>to that new machine, or I'll have to request a
>new one ? If the transfer is possible, how can I do that ?
>I'm a newbie on AGTk 2.1.x on Windows; I was used to use
>version 1.1, only on Linux machines.
>Thanks in advance.
>Rogerio
>_________________
>Rogerio Luiz Iope
>Centro de Computacao Eletronica
>Universidade de Sao Paulo (USP)
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20031016/250e17d7/attachment.htm>
