AW: AW: [AG-TECH] video card question
Brunner, Armin
armin.brunner at id.ethz.ch
Fri Nov 21 05:27:45 CST 2003
It's easy ;-) The Winnov support crew helped a lot.
You have to fiddle in the registry :-(
citation:
Go to HKLM\system\CurrentControlSet\Services\Winnov32\Vidsrc\SAA7114\Board0\Source
Try change the value to 1. reboot the machine once.
If you want to use the 2nd, 3rd and 4th device, do the same for board1, board2 and board3.
citation end.
After this change (it works really) I was facing the next problem.
All the videos were upside down but there was a solution for this also.
citation:
HKEY_ CURRENT_USER\Software\Winnov\Videum\vic.exe0
Add a Dword called Vflip and set its value to 1. do the same for all copies of vic.exe you find under HKLM or HKCU and under other users.
citation end.
Our video computer: Dual Xeon, WinXP (with all patches and SPs),
Winnov Videum 4400AV, Driver 2.13
Armin
Armin Brunner e-mail: armin.brunner at id.ethz.ch
Leiter Kommunikation Tel: +41-1-632'3538
RZ, ETH-Zentrum Fax: +41-1-632'1225
CH-8092 Zurich Switzerland
.... Und aus dem Chaos sprach eine Stimme zu mir:
"Laechle und sei froh, denn es koennte schlimmer kommen!"
.... Ich laechelte und war froh - und es kam schlimmer.
>-----Ursprüngliche Nachricht-----
>Von: owner-ag-tech at mcs.anl.gov
>[mailto:owner-ag-tech at mcs.anl.gov] Im Auftrag von Cindy Sievers
>Gesendet: Mittwoch, 19. November 2003 20:23
>An: Jimmy Miklavcic; Access Grid
>Betreff: Re: AW: [AG-TECH] video card question
>What exactly did Armin Brunner do to make the Winnov Videum
>quad card work
>with vic? I think that there are lots of us who would like to
>know....:)
>At 08:21 AM 11/19/2003, Jimmy Miklavcic wrote:
>>In one system I have 2 Osprey 220 cards and 2 Osprey 230 cards in a
>>single
>>Windows XP Dual 3.0 GHz box. Works like a charm.
>>In another system I have two video capture machines with 4 in
>one and 3
>>in
>>another (total 7). An they all work fine, although these are
>linux boxes.
>>Jimmy
>>Brunner, Armin wrote:
>>>I can confirm this. With WinXP only ONE Haupauge WinTV card is
>>>supported.
>>>Workaround: several computers with one haupauge card each
>>>or other video capturing card. I'm using a Winnov Videum 4400 4 port
>>>card (it's possible to bring this card to work with vic). Regards
>>>Armin
>>Jimmy Miklavcic
>>Multimedia Specialist
>>jhm at chpc.utah.edu
>>UNIVERSITY OF UTAH
>>CTR FOR HIGH PERFORM COMPUTING
>>155 SOUTH 1452 EAST RM 405
>>SALT LAKE CITY, UT 84112-0190
>>Office: 801.585.9335
>> Fax: 801.585.5366
>>http://www.chpc.utah.edu/~jhm
>>http://www.anotherlanguage.org
>Cindy Sievers Los Alamos National Laboratory
>sievers at lanl.gov Group CCS-1 MS B287
>tel:505.665.6602 Advanced Computing
>fax:505.665.4939 Los Alamos, NM 87544
