[AG-TECH] AddServiceManager error
    Jon I Johansson
    jon.johansson at ualberta.ca
    Thu Nov  6 11:58:09 CST 2003
Hi Thomas,
I've attached agns.log and agsm.log as you asked and
included VenueClient.log.
I've also copied AG-Tech this time.
Thank you for your help.
Jon.
Jon I Johansson             *  Research Computing Support
jon.johansson at ualberta.ca   *  Computing and Network Services
Tel.: (780) 492-9304        *  University of Alberta
Fax.: (780) 492-1729        *  Edmonton, Alberta, CANADA
> -----Original Message-----
> From: Thomas D. Uram [mailto:turam at mcs.anl.gov]
> Sent: Wednesday, November 05, 2003 7:09 PM
> To: Jon I Johansson
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] AddServiceManager error
> Jon:
> If you send the agns.log and agsm.log files, I'll have a look and see
> what's going wrong.  You can find these files in C:\Documents and
> Settings\<YOU>\Application Data\AccessGrid.
> Tom
> Jon I Johansson wrote:
> >Hi,
> >I am running AG 2.1.2 on my Windows XP display machine and trying
> >to add a Service Manager. I am trying to add a service manager
> >on the display machine and I'm getting "Error adding service manager"
> >I've included outputs from AGServiceManager, AGNodeService and
> >NodeManagement below. The host names that I've putting into the
> >Add Service Manager Dialog box is ag-display and
> ag-display.cns.ualberta.ca
> >Do I need to include some other info as the host name?
> >Thanks,
> >Jon.
> >The AGServiceManager is running and reports:
> >AGServiceManager URL:
> >https://ag-display.cns.ualberta.ca:12000/ServiceManager
> >The NodeService reports:
> >C:\Program Files\Access Grid Toolkit\bin>python AGNodeService.py
> >AGNodeService URL:
> https://ag-> display.cns.ualberta.ca:11000/NodeService
> >The
> NodeManagement reports:
> >C:\Program Files\Access Grid Toolkit\bin>python NodeManagement.pyw
> >Traceback (most recent call last):
> >  File
> >"C:\Python22\Lib\site-packages\AccessGrid\NodeManagementUICla
> sses.py", li
> >ne 676, in AddHost
> >    self.UpdateHostList()
> >  File
> sses.py", li
> >ne 719, in UpdateHostList
> >    self.serviceManagers =
> >self.nodeServiceHandle.GetProxy().GetServiceManagers(
> >  File
> >"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\AG
> GSISOAP.py",
> > line 3660, in __call__
> >    return self.__r_call(*args, **kw)
> >  File
> GSISOAP.py",
> > line 3680, in __r_call
> >    self.__hd, self.__ma)
> >  File
> GSISOAP.py",
> > line 3580, in __call
> >    config = self.config)
> >  File
> GSISOAP.py",
> > line 3464, in call
> >    r.endheaders()
> >  File "C:\Python22\lib\httplib.py", line 695, in endheaders
> >    self._send_output()
> >  File "C:\Python22\lib\httplib.py", line 581, in _send_output
> >    self.send(msg)
> >  File "C:\Python22\lib\httplib.py", line 548, in send
> >    self.connect()
> >  File "C:\Python22\lib\httplib.py", line 532, in connect
> >    raise socket.error, msg
> >socket.error: (10049, "Can't assign requested address")
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20031106/3a1f3c72/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20031106/3a1f3c72/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20031106/3a1f3c72/attachment-0002.obj>
