[AG-TECH] Ag2.0 Install on Debian Linux
Eric Olson
eolson at mcs.anl.gov
Thu May 29 12:05:22 CDT 2003
Jason,
Information on running from cvs source is in the README-developers file.
If you haven't obtained the source yet, there are instructions on how to
retrieve it under the Source Code link on the web page.
Eric
On Wed, 28 May 2003, Jason wrote:
> I'm working on trying to install the Ag2.0 software on Debian and have
> tried to use the rpm's and even gone as far as using alien to convert
> the rmps to debian packages.
> Using the instructions at
> http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid I get errors.
> The problem I have run into either way is that the setup-gsi script is
> failing while executing grid-security-config. The grid-security.config
> file is created just fine, but there is some problem I can't resolve
> when it configures. The script is bailing out at line 133 of
> /usr/lib/globus/setup/globus/setup-gsi.pl if that helps anyone who may
> offer a response.
> My question is this: Can I install from the CVS source and where would
> information about installing from the CVS source be located? I have all
> the prerequisite software that is available in debian packages
> (Python2.2, libwxgtk2.2, libwxgtk2.2-python, python logging) installed
> and it appears to be ready, but the error above has me stuck in my tracks.
> Thanks,
> Jason Hill
> jahill at scl.ameslab.gov
> Ames Laboratory, SCL
> 310 Wilhelm Hall
> Ames, IA 50010
