[AG-TECH] Ag2.0 Install on Debian Linux
Julian Yu-Chung Chen
ycc at nchc.gov.tw
Fri May 30 01:03:07 CDT 2003
Hi there,
I made a successful attempt to install AG2.0rc1 in Debian GNU/Linux in
the last few weeks. So I'd like to share some of my experience here.
My test machine is using Debian GNU/Linux Woody.
I write up a script, inst.sh, to help me do things faster in several
different machines. My working directory looks like this,
AG_inst/
2.0/RPMS/
req/
inst.sh
I placed pre-require software in req/ directory, all of them are
downloaded in
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/releases/2.0-rc1/redhat.html
Includes,
PyIPC-20030428-1.i386.rpm
pyGlobus-cvs-4.i386.rpm
globus-accessgrid-2.0-1.i386.rpm
pyOpenSSL-0.5.1-1.i386.rpm
gpt-1.0-2.i386.rpm
wxGTK-2.4.0-1.i386.rpm
logging-0.4.7-2.i386.rpm
wxPythonGTK-py2.2-2.4.0.7-1.i386.rpm
Notice that through some packages are also provided in Debian's APT, but
due to version info and dependency problems(mostly python version number
with related libraries), you have to use these packages from anl.
ps.
And in pyOpenSSL, anl added their own implementation methods. I'm not
sure whether it's taken cared of in the latest version by Robert.
See this mailing thread,
http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2003/05/msg00150.html
AG related packages are placed in 2.0/RPMS/ directory. Includes,
AccessGrid-2.0RC-1.i386.rpm
AccessGrid-AudioService-2.0RC-1.i386.rpm
AccessGrid-VenueClient-2.0RC-1.i386.rpm
AccessGrid-VenueServer-2.0RC-1.i386.rpm
AccessGrid-VideoConsumer-2.0RC-1.i386.rpm
AccessGrid-VideoProducer-2.0RC-1.i386.rpm
AccessGrid-rat-4.2.22-1.i386.rpm
AccessGrid-vic-2.8ucl1.1.3-1.i386.rpm
The script is basically translate .RPM files to .deb files and install
them, and running several commands to setup Globus GSI correctly.
And with minor mods you can also install in sid.
my 2 cents.
Ivan R. Judson wrote:
>By the way Jason, if you're insterested in contributing those packages to
>the community we'd be happy to add them to our web pages. We're more than
>happy to make them available.
>Thanks,
>--Ivan
>>-----Original Message-----
>>From: owner-ag-tech at mcs.anl.gov
>>[mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Ti Leggett
>>Sent: Thursday, May 29, 2003 9:02 AM
>>To: Jason
>>Cc: AG Tech
>>Subject: Re: [AG-TECH] Ag2.0 Install on Debian Linux
>>On Wed, 2003-05-28 at 20:48, Jason wrote:
>>>I'm working on trying to install the Ag2.0 software on
>>Debian and have
>>>tried to use the rpm's and even gone as far as using alien
>>to convert
>>>the rmps to debian packages.
>>>Using the instructions at
>>>http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid I get errors.
>>>The problem I have run into either way is that the
>>setup-gsi script is
>>>failing while executing grid-security-config. The
>>grid-security.config
>>>file is created just fine, but there is some problem I
>>can't resolve
>>>when it configures. The script is bailing out at line 133 of
>>>/usr/lib/globus/setup/globus/setup-gsi.pl if that helps
>>anyone who may
>>>offer a response.
>>There's several commands you need to run after installing
>>Globus to get it setup. First and foremost you must have gpt
>>installed. After that you should be able to do the following:
>>. /etc/profile.d/gpt.sh
>>. /etc/profile.d/globus.sh
>>${GPT_LOCATION}/sbin/gpt_verify ${GPT_LOCATION}/sbin/gpt-postinstall
>>/usr/lib/globus/setup/globus_simple_ca_45cc9e80_setup/setup-gs
>>i -default
>>>My question is this: Can I install from the CVS source and
>>where would
>>>information about installing from the CVS source be
>>located? I have all
>>>the prerequisite software that is available in debian packages
>>>(Python2.2, libwxgtk2.2, libwxgtk2.2-python, python
>>logging) installed
>>>and it appears to be ready, but the error above has me
>>stuck in my tracks.
>>>Thanks,
>>>Jason Hill
>>>jahill at scl.ameslab.gov
>>>Ames Laboratory, SCL
>>>310 Wilhelm Hall
>>>Ames, IA 50010
-------------------------- Codito, ergo sum ----------------------------
Julian Yu-Chung Chen ycc at nchc.gov.tw julian9@[acm.org|mac.com]
National Center for Work Phone: +886-3-5776085 ext 354
High-performance Computing Mobile Phone: +886-(0)932-XXX-XXX
Type: text/x-sh
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030530/fd425683/attachment.sh>
