[AG-TECH] Open Mash still in process?
Ivan R. Judson
judson at mcs.anl.gov
Wed May 28 06:47:49 CDT 2003
Very nice.
My motivation to use common comes from a long-standing desire to see the
integration of the various projects into a single supported source
repository. The engineering is secondary. I'm guessing this will either not
happen or take a very long time :-)
--Ivan
> -----Original Message-----
> From: Andrew Swan [mailto:aswan at cs.berkeley.edu]
> Sent: Wednesday, May 28, 2003 12:42 AM
> To: Robert Olson
> Cc: Ivan R. Judson; 'Randy Groves'; ag-tech at mcs.anl.gov;
> openmash-developers at openmash.org
> Subject: Re: [AG-TECH] Open Mash still in process?
> Robert Olson wrote:
> > > although the ucl common library does have support for
> des, it has no
> > > support for Rijndael.
> > Late-model common should; I added that support to enable
> AES for rat,
> > and
> > I believe the mods made it into the UCL CVS tree.
> ah, i was looking at the version in the public ag cvs
> repository. is that version older than the most recent ucl version?
> > > it would be pretty easy to port the crypt-rijndael.cpp file from
> > > ag-vic to mash if the ag community would find that useful.
> > Yup, I think it definitely would. I agree about it being
> pretty easy;
> > the
> > port of the code from DES to Rijndael was pretty
> straightforward (most of
> > the time spent debugging boneheaded cut and paste errors).
> i just checked the rijndael code from agvic in to the
> openmash cvs repository. if you've already got a copy of
> openmash checked out, just "cvs update -d" and re-run
> configure with --enable-rijndael. i did some quick&dirty
> testing with agvic and they seem to interoperate just fine...
> -Andrew
