[AG-TECH] Open Mash still in process?
Bob Riddle
bdr at internet2.edu
Wed May 28 08:05:19 CDT 2003
Hey, I'd like to help with this, pick up the Openmash code from Larry
when he retires, and maybe have a student work on this in his spare time
... thoughts?
Ivan R. Judson wrote:
>Very nice.
>My motivation to use common comes from a long-standing desire to see the
>integration of the various projects into a single supported source
>repository. The engineering is secondary. I'm guessing this will either not
>happen or take a very long time :-)
>--Ivan
>>-----Original Message-----
>>From: Andrew Swan [mailto:aswan at cs.berkeley.edu]
>>Sent: Wednesday, May 28, 2003 12:42 AM
>>To: Robert Olson
>>Cc: Ivan R. Judson; 'Randy Groves'; ag-tech at mcs.anl.gov;
>>openmash-developers at openmash.org
>>Subject: Re: [AG-TECH] Open Mash still in process?
>>Robert Olson wrote:
>>>>although the ucl common library does have support for
>>des, it has no
>>>>support for Rijndael.
>>>Late-model common should; I added that support to enable
>>AES for rat,
>>>and
>>>I believe the mods made it into the UCL CVS tree.
>>ah, i was looking at the version in the public ag cvs
>>repository. is that version older than the most recent ucl version?
>>>>it would be pretty easy to port the crypt-rijndael.cpp file from
>>>>ag-vic to mash if the ag community would find that useful.
>>>Yup, I think it definitely would. I agree about it being
>>pretty easy;
>>>the
>>>port of the code from DES to Rijndael was pretty
>>straightforward (most of
>>>the time spent debugging boneheaded cut and paste errors).
>>i just checked the rijndael code from agvic in to the
>>openmash cvs repository. if you've already got a copy of
>>openmash checked out, just "cvs update -d" and re-run
>>configure with --enable-rijndael. i did some quick&dirty
>>testing with agvic and they seem to interoperate just fine...
>>-Andrew
Bob Riddle (bdr at internet2.edu) Technologist,Internet2
3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
Business Phone: 734.913.4257 Fax Number: 734.913.4255
"Opportunity is missed by most people because it is dressed in overalls and looks like work" Thomas Edison
