[AG-TECH] Open Mash still in process?
Andrew Swan
aswan at cs.berkeley.edu
Wed May 28 00:42:08 CDT 2003
Robert Olson wrote:
> > although the ucl common library does have support for des,
> > it has no support for Rijndael.
> Late-model common should; I added that support to enable AES for rat, and
> I believe the mods made it into the UCL CVS tree.
ah, i was looking at the version in the public ag cvs
repository. is that version older than the most recent
ucl version?
> > it would be pretty easy to port the crypt-rijndael.cpp file
> > from ag-vic to mash if the ag community would find that
> > useful.
> Yup, I think it definitely would. I agree about it being pretty easy; the
> port of the code from DES to Rijndael was pretty straightforward (most of
> the time spent debugging boneheaded cut and paste errors).
i just checked the rijndael code from agvic in to the openmash
cvs repository. if you've already got a copy of openmash
checked out, just "cvs update -d" and re-run configure with
--enable-rijndael. i did some quick&dirty testing with agvic
and they seem to interoperate just fine...
-Andrew
