[AG-TECH] starting venue server
Ivan R. Judson
judson at mcs.anl.gov
Mon May 12 16:04:18 CDT 2003
Hey Dave,
You haven't missed it; this stuff is on my plate to get done ASAP.
The url you should try is: https://zim.ncsa.uiuc.edu:8000/Venues/default;
the other thing you can do, once that's there is run VenueManagement.py, and
when it comes up type in the url: https://zim.ncsa.uiuc.edu:8000/VenueServer
in the address bar and hit go.
That should get your venue management client pointed at your server, from
there you can add, modify, and delete venues, you can also modify the server
config. Let me know if you try this and how it goes, I'd like us to get
feedback so we can try to catch anything that's awkward before final :-)
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Dave Semeraro
> Sent: Monday, May 12, 2003 3:54 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] starting venue server
> Hi,
> Can someone tell me the steps required to start a venue
> server and connect
> to it with a
> venue client. I have the following situation. I have
> installed ag20 rc1 on
> a windows xp laptop.
> I started the venue server from the start menue. I verified it did
> something by looking in the
> log file. I then tried to connect to it with the venue
> client. I typed in
> "https://zim.ncsa.uiuc.edu:8000/Venues" in the appropriate
> window and hit
> the go button. I was
> treated to the "invalid url" once again. So when a venue
> server is started
> with no arguments what
> is the correct url to give the venue client that will allow
> it to connect?
> Also how does one
> configure the server? None of this information was easily
> found in any of
> the docs. Perhaps
> I looked in the wrong place.
> Thanks in advance.
> Dave
> Dave Semeraro Ph.D.
> Visualization and Virtual Environments Group
> NCSA University of Illinois
> 605 E. Springfield Ave.
> Champaign, IL 61820
> Semeraro at ncsa.uiuc.edu
> (217) 244-1852
