[AG-TECH] starting venue server
Dave Semeraro
semeraro at ncsa.uiuc.edu
Mon May 12 16:14:09 CDT 2003
Ivan,
Thanks, I used the url you suggested and it worked. I had also done some
experimenting
before you sent the mail and found some stuff out myself. I started the
venue server from
a command line and it told me that it had started at
"https://zim.ncsa.uiuc.edu:8000/VenueServer" so I put that url into my
client and it connected. I
also fired up the venue manager and connected to that url. I added another
venue, or at least
I thought I did. When I fired up the client again I didnt see any "little
doors" leading to the
new venue I created. Do I have to whack the server and start it again?
Dave
At 04:04 PM 5/12/2003 -0500, Ivan R. Judson wrote:
>Hey Dave,
>You haven't missed it; this stuff is on my plate to get done ASAP.
>The url you should try is: https://zim.ncsa.uiuc.edu:8000/Venues/default;
>the other thing you can do, once that's there is run VenueManagement.py, and
>when it comes up type in the url: https://zim.ncsa.uiuc.edu:8000/VenueServer
>in the address bar and hit go.
>That should get your venue management client pointed at your server, from
>there you can add, modify, and delete venues, you can also modify the server
>config. Let me know if you try this and how it goes, I'd like us to get
>feedback so we can try to catch anything that's awkward before final :-)
>--Ivan
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Dave Semeraro
> > Sent: Monday, May 12, 2003 3:54 PM
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] starting venue server
> > Hi,
> > Can someone tell me the steps required to start a venue
> > server and connect
> > to it with a
> > venue client. I have the following situation. I have
> > installed ag20 rc1 on
> > a windows xp laptop.
> > I started the venue server from the start menue. I verified it did
> > something by looking in the
> > log file. I then tried to connect to it with the venue
> > client. I typed in
> > "https://zim.ncsa.uiuc.edu:8000/Venues" in the appropriate
> > window and hit
> > the go button. I was
> > treated to the "invalid url" once again. So when a venue
> > server is started
> > with no arguments what
> > is the correct url to give the venue client that will allow
> > it to connect?
> > Also how does one
> > configure the server? None of this information was easily
> > found in any of
> > the docs. Perhaps
> > I looked in the wrong place.
> > Thanks in advance.
> > Dave
> > Dave Semeraro Ph.D.
> > Visualization and Virtual Environments Group
> > NCSA University of Illinois
> > 605 E. Springfield Ave.
> > Champaign, IL 61820
> > Semeraro at ncsa.uiuc.edu
> > (217) 244-1852
Dave Semeraro Ph.D.
Champaign, IL 61820
(217) 244-1852
