[AG-TECH] Hi, How can I set up a venue server ?
Ivan R. Judson
judson at mcs.anl.gov
Mon May 12 06:06:09 CDT 2003
I'll answer question #2, but leave question #1 to someone who can help you better.
The source for the 2.0 Venue Server is in cvs (http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/cvs/index.html), the AccessGrid module. The executable is in bin/VenueServer.py. It will run with no changes (except setting up your environment with bin/cvssetup.py) and listen on ports 8000, 8002, 8004, 8006.
The other way to use it is to use the one installed with the AGTk RC1 which works the same way, but doesn't require you to setup your environment. I'll work on documentation for it today.
--Ivan
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of ¹®Á¤ÈÆ
Sent: Monday, May 12, 2003 4:29 AM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Hi, How can I set up a venue server ?
<http://150.183.95.96/cgi-bin/setconfirm.cgi?k=1052731672254598&u=jhmoon&d=kisti.re.kr>
Hi Everyone
I need some help
1. I want to set up a venue server.
I have already venue server rpm(ag-vv-1.0.00-1)
In spite of already installed apache whenever I install the venue server rpm that required the apache(Error message is "Failed dependencies : apache is needed by ag-vv-1.0.00-1")
I already installed Red Hat 7.3 include apache which is support by Red Hat
How can I fix it ?
2. How can I get a venue server 2.0 source ?
thank you so much
jeong-hoon
<mailto:ag-tech at mcs.anl.gov>
Jeong-hoon, Moon
Researcher
High Performance Research Networking Dep.
Korea Institute of Science and Technology Information(KISTI)
Tel:+82-42-869-0578
Fax:+82-42-869-0589
email : jhmoon at kisti.re.kr otello at kebi.com
한국과학기술정보연구원
슈퍼컴퓨팅센터
초고속연구망개발실
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030512/24d06cab/attachment.htm>
