[AG-TECH] Re: [APAG] Help installing ag software
Ivan R. Judson
judson at mcs.anl.gov
Wed Mar 12 01:21:32 CST 2003
Thanks!
Now you can be sure we'll fix it in a reasonable timeframe.
Thanks for using the alpha, the feedback is very valuable.
--Ivan
> -----Original Message-----
> From: Sugree Phatanapherom [mailto:g4465027 at ku.ac.th]
> Sent: Tuesday, March 11, 2003 9:39 PM
> To: judson at mcs.anl.gov; ag-tech at mcs.anl.gov; 'George Estes'
> Subject: Re: [AG-TECH] Re: [APAG] Help installing ag software
> http://bugzilla.mcs.anl.gov/AccessGrid/show_bug.cgi?id=152
> > Hey Sugree,
> > Can you file this as a bug in our bugzilla system? This
> sounds like it
> > is just wrong, not something you should have to work around :-).
> > Thanks for all your work on this. I appreciate it very much.
> > --Ivan
> > > From: owner-ag-tech at mcs.anl.gov
> > > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Sugree
> Phatanapherom
> > > Sent: Tuesday, March 11, 2003 4:05 AM
> > > To: ag-tech at mcs.anl.gov; George Estes
> > > When you join any Venue, vic and rat are automatically
> > > started. Anyway, you have to "quit" the first instance of them.
> > > I found that ProcessManagerUnix.py attempts to kill the
> > > process by sending SIGINT and then waitpid. For my
> > > experience, the processes don't quit at all. I tried SIGQUIT
> > > but got the same problem. Currently, I use SIGKILL and it
> > > works fine. If you don't want to change the code, just quit
> > > vic or rat whenever VenueClient or NodeManagement are not
> responding.
> > > > Before starting any programs, please change directory to
> > > > /usr/share/AccessGrid
> > > > ----- Original Message -----
> > > > From: "George Estes" <gestes at ncsa.uiuc.edu>
> > > > To: "Sugree Phatanapherom" <g4465027 at ku.ac.th>;
> > > <ag-tech at mcs.anl.gov>
> > > > Sent: Tuesday, March 11, 2003 2:13 AM
> > > > > Did you find a solution to this problem? I'm getting the same
> > > > > error.
> > > > > George
> > > > > At 05:22 PM 3/4/2003 +0700, Sugree Phatanapherom wrote:
> > > > > >Envelope-From: owner-ag-tech at mcs.anl.gov
> > > > > >From: "Sugree Phatanapherom" <g4465027 at ku.ac.th>
> > > > > >To: "Jason Bell" <j.bell at cqu.edu.au>, <ag-tech at mcs.anl.gov>,
> > > > > > <apag at prg.cpe.ku.ac.th>
> > > > > >Cc: <chris at vislab.usyd.edu.au>, <Dominique.Morel at jcu.edu.au>,
> > > > > > <m.barry at qut.edu.au>
> > > > > >Subject: [AG-TECH] Re: [APAG] Help installing ag software
> > > > > >Date: Tue, 4 Mar 2003 17:22:38 +0700
> > > > > >X-Mailer: Microsoft Outlook Express 6.00.2800.1106
> > > > > >X-Spam-Level: *
> > > > > >X-Spam-Status: No, hits=1.5 required=5.0
> > > > > >tests=FROM_ENDS_IN_NUMS,PORN_14,WEIRD_PORT version=2.21
> > > > > >X-Spam-Level: *
> > > > > >Sender: owner-ag-tech at mcs.anl.gov
> > > > > >X-MD5SUM: add6114a31e574b7227f101c50aa9f32
> > > > > >Hi,
> > > > > >In my opinion, you should try both AG 1.0 and AGtk
> 2.0 to keep
> > > > > >track of
> > > > the
> > > > > >development. I wrote a brief step-by-step installation guide
> > > > > >for
> > > > > >later
> > > > use.
> > > > > >You may be interesting to read it as a guide-line.
> > > > > >http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid
> > > > > >Anyway, I got errors while trying to add services.
> > > Service Manager
> > > should
> > > > > >find AudioService in local_services but it didn't
> find. Then,
> > > > > >it
> > > > > >tried
> > > to
> > > > > >load the service online but again it read on wrong
> directory.
> > > > > >The
> > > correct
> > > > > >value might be services/AudioService.zip. I guess
> that Service
> > > > > >Manager
> > > is
> > > > > >confusing the use of local_services and services.
> > > > > >===> cut here <===
> > > > > >Retrieving Service Package:
> >https://prg-34-13.cpe.ku.ac.th:62556/packages/AudioService.zi
p
> > > > >Exception in AddService, retrieving service implementation
> > > > >-- exceptions.IOError [Errno 2] No such file or directory:
> > > > >'local_services/AudioService.zip'
> > > > >*** Method AddService exception
> > > > >Traceback (most recent call last):
> > > > > File
> > >"/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus
> /AGGSISOAP
> > >.py"
> > > > >line 3839, in do_POST
> > > > > fr = apply(f, args, {'_SOAPContext':c})
> > > > > File
> > >"/usr/lib/python2.2/site-packages/AccessGrid/hosting/AccessControl.
> > > > >py",
> > > line
> > > > >285, in __call__
> > > > > raise fault
> > > > >faultType: <Fault : <Fault AGServiceManager.AddService failed:
> > > > >[Errno
> > 2]
> > > No
> > > > >such file or directory: 'local_services/AudioService.zip': >>
