[AG-TECH] Globus Certificate
Brian Corrie
brian.corrie at newmic.com
Wed Mar 5 14:56:37 CST 2003
All,
This was discussed at the TownHall meeting yesterday. I saw the same
behaviour. When you do the install it appears that when asked to create a
certificate it fails for some reason. It will create the appropriate files if
you go into the Win Globus menu (under Programs) and generate a certificate
after the install is finished. The files will then be created correctly. I am
not sure where they are created the first time... Bob, I have not created
this as a bug with bugzilla, so you might want to do that!
Cheers,
Brian
> -----Original Message-----
> From: Sam Liston [mailto:stliston at chpc.utah.edu]
> Sent: Wednesday, March 05, 2003 10:29 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Globus Certificate
> I have followed the AGTk2.0 "Getting Started" instructions, when I got
> to the point of installing WinGlobus and when asked if I wanted to
> request a certificate I said "yes". It said userreq.pem would be
> created in C:\Douments adn Settings\<user>\Application
> Data\.globus. It
> created the directory, but it didn't create the file.
> What am I doing wrong?
> Sam
