[AG-TECH] Globus Certificate
Ti Leggett
leggett at mcs.anl.gov
Wed Mar 5 17:38:27 CST 2003
I'm going to look into this probably tonight. I thought it worked for
me, but I could very well be mistaken.
On Thu, 2003-03-06 at 05:56, Brian Corrie wrote:
> All,
> This was discussed at the TownHall meeting yesterday. I saw the same
> behaviour. When you do the install it appears that when asked to create a
> certificate it fails for some reason. It will create the appropriate files if
> you go into the Win Globus menu (under Programs) and generate a certificate
> after the install is finished. The files will then be created correctly. I am
> not sure where they are created the first time... Bob, I have not created
> this as a bug with bugzilla, so you might want to do that!
> Cheers,
> Brian
> > -----Original Message-----
> > From: Sam Liston [mailto:stliston at chpc.utah.edu]
> > Sent: Wednesday, March 05, 2003 10:29 AM
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] Globus Certificate
> > I have followed the AGTk2.0 "Getting Started" instructions, when I got
> > to the point of installing WinGlobus and when asked if I wanted to
> > request a certificate I said "yes". It said userreq.pem would be
> > created in C:\Douments adn Settings\<user>\Application
> > Data\.globus. It
> > created the directory, but it didn't create the file.
> > What am I doing wrong?
> > Sam
