[AG-TECH] Problems with access grid shared browser
    Thomas Uram
    turam at mcs.anl.gov
    Thu Jun 19 16:17:49 CDT 2003
Ferdinand:
The errors you are getting could also occur if you haven't installed the
shared browser.  This component is not included in the standard AG2
release.  It is a separate installer, available from the same web page
where you retrieved the AG2 software.
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/releases/2.0/windows.html
The installer should set up your mailcap file properly.
Tschuess,
Tom
Ti Leggett wrote:
>Yes, in fact that's what I was going to have you do. :)
>>From the command line, if you run:
>python MailcapSetup.py --help
>It should print out some usage information (this assumes python is in
>your path). Here's a quick and dirty tutorial:
>python MailcapSetup.py --mime-type "application/x-ag-shared-browser"
>--executable "C:\Documentst and Settings\All Users\Application
>Data\AccessGrid\applications\SharedBrowser\SharedBrowser.py"
>--description "This is the shared browser" --nametemplate
>"sharedbrowser"
>That should generate a file in C:\Documents and
>Settings\<username>\Application Data\AccessGrid\mailcap
>Please let me know if there are any errors or if it doesn't generate the
>file. Thanks!
>On Tue, 2003-06-17 at 09:29, Ferdinand Hommes wrote:
>>Yes, mailcapSetup.py is within the AGTk 2.0 directory. Can I generate
>>the mailcap file manualy by using this program?
>>>-----Original Message-----
>>>From: Ti Leggett [mailto:leggett at mcs.anl.gov]
>>>Sent: Tuesday, June 17, 2003 4:27 PM
>>>To: Ferdinand Hommes
>>>Cc: 'AG Tech'; ag-users at mcs.anl.gov
>>>Subject: RE: [AG-TECH] Problems with access grid shared browser
>>>That shouldn't make much difference as it get's the name for
>>>that folder out of the registry. Do you have C:\Program
>>>Files\AGTk 2.0\MailcapSetup.py (replacing c:\Program Files
>>>with wherever you installed it)?
>>>On Tue, 2003-06-17 at 08:49, Ferdinand Hommes wrote:
>>>>Unfortunately I could not find any mailcap files within the
>>>>directories you indicated and within any other directory.
>>>Installation
>>>>und using AGTk have been done with the same Userid. I am using the
>>>>German version of Windows XP, which means, that the directory
>>>>c:\Documents and Settings is called c:\Dokumente und Einstellungen
>>>>Kind Regards
>>>>Ferdi
>>>>>Sent: Tuesday, June 17, 2003 3:21 PM
>>>>>Cc: AG Tech; ag-users at mcs.anl.gov
>>>>>Subject: Re: [AG-TECH] Problems with access grid shared browser
>>>>>For whatever reason you don't have a valid mailcap file. Can
>>>>>you send the mailcap file from c:\\Administrator\Application
>>>>>and also from C:\Documents and
>>>>>Settings\<username>\Application Data\AccessGrid\mailcap wher
>>>>><username> is the user you're trying to run as. Also, did you
>>>>>by chance install the AGTk as another user than the one
>>>>>you're currently running as?
>>>>>On Tue, 2003-06-17 at 04:20, Ferdinand Hommes wrote:
>>>>>>Hello,
>>>>>>I am using AG 2.0 with windows XP. When I try to start
>>>the Shared
>>>>>>Browser application I get the following error message:
>>>>>>No Client registered for the selected application
>>>>>>(mime type = application/x-ag-shared-browser)
>>>>>>How can I register a client?
>>>>>>Kind regards
>>>>>>Ferdi
>>>>>>Ferdinand Hommes
>>>>>>Fraunhofer-Institut für Medienkommunikation IMK
>>>>>>Schloss Birlinghoven
>>>>>>D 53754 Sankt Augustin
>>>>>>Germany
>>>>>>Tel. +49 2241 141932
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030619/f2902674/attachment.htm>
