[AG-TECH] Problems with access grid shared browser
Ferdinand Hommes
Ferdinand.Hommes at imk.fraunhofer.de
Fri Jun 20 02:52:30 CDT 2003
Tom,
I have installed Shared Browser and Shared Presentation using the files
from the website you indicated. Unfortunately no mailcap file is setup.
Can you plkease provide me the mailcap entry for shared presentation?
Tschö ( Cologne Version of Tschuess)
Ferdi
-----Original Message-----
Sent: Thursday, June 19, 2003 11:18 PM
To: Ti Leggett
Cc: Ferdinand Hommes; 'AG Tech'; ag-users at mcs.anl.gov
Subject: Re: [AG-TECH] Problems with access grid shared browser
Ferdinand:
The errors you are getting could also occur if you haven't installed the
shared browser. This component is not included in the standard AG2
release. It is a separate installer, available from the same web page
where you retrieved the AG2 software.
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/releases/2.0
/windows.html
The installer should set up your mailcap file properly.
Tschuess,
Tom
Ti Leggett wrote:
Yes, in fact that's what I was going to have you do. :)
python MailcapSetup.py --help
It should print out some usage information (this assumes python is in
your path). Here's a quick and dirty tutorial:
python MailcapSetup.py --mime-type "application/x-ag-shared-browser"
--executable "C:\Documentst and Settings\All Users\Application
Data\AccessGrid\applications\SharedBrowser\SharedBrowser.py"
--description "This is the shared browser" --nametemplate
"sharedbrowser"
That should generate a file in C:\Documents and
Settings\<username>\Application Data\AccessGrid\mailcap
Please let me know if there are any errors or if it doesn't generate the
file. Thanks!
On Tue, 2003-06-17 at 09:29, Ferdinand Hommes wrote:
Yes, mailcapSetup.py is within the AGTk 2.0 directory. Can I generate
the mailcap file manualy by using this program?
Sent: Tuesday, June 17, 2003 4:27 PM
To: Ferdinand Hommes
Cc: 'AG Tech'; ag-users at mcs.anl.gov
Subject: RE: [AG-TECH] Problems with access grid shared browser
That shouldn't make much difference as it get's the name for
that folder out of the registry. Do you have C:\Program
Files\AGTk 2.0\MailcapSetup.py (replacing c:\Program Files
with wherever you installed it)?
On Tue, 2003-06-17 at 08:49, Ferdinand Hommes wrote:
Unfortunately I could not find any mailcap files within the
directories you indicated and within any other directory.
Installation
und using AGTk have been done with the same Userid. I am using the
German version of Windows XP, which means, that the directory
c:\Documents and Settings is called c:\Dokumente und Einstellungen
Kind Regards
Ferdi
Sent: Tuesday, June 17, 2003 3:21 PM
Cc: AG Tech; ag-users at mcs.anl.gov
For whatever reason you don't have a valid mailcap file. Can
you send the mailcap file from c:\\Administrator\Application
and also from C:\Documents and
Settings\<username>\Application Data\AccessGrid\mailcap wher
<username> is the user you're trying to run as. Also, did you
by chance install the AGTk as another user than the one
you're currently running as?
On Tue, 2003-06-17 at 04:20, Ferdinand Hommes wrote:
Hello,
I am using AG 2.0 with windows XP. When I try to start
the Shared
Browser application I get the following error message:
No Client registered for the selected application
(mime type = application/x-ag-shared-browser)
How can I register a client?
Kind regards
Ferdi
Ferdinand Hommes
Fraunhofer-Institut für Medienkommunikation IMK
Schloss Birlinghoven
D 53754 Sankt Augustin
Germany
Tel. +49 2241 141932
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030620/054ef6e6/attachment.htm>
