[AG-USERS] RE: [AG-TECH] Problems with access grid shared browser
    Ferdinand Hommes
    Ferdinand.Hommes at imk.fraunhofer.de
    Wed Jun 18 03:39:09 CDT 2003
Yes, now it works. Due to our German environment I had to change some
Pathnames:
python "c:\programme\AGTk 2.0\MailcapSetup.py" --mime-type
"application/x-ag-shared-browser" --executable "C:\Dokumente und
Einstellungen\All
Users\Anwendungsdaten\AccessGrid\applications\SharedBrowser\SharedBrowse
r.py" --description "This is the shared browser" --nametemplate
"sharedbrowser"
The problem exists with Shared Presentation, too. Derived from the
Shared Browser I tried the following command:
"application/x-ag-shared-presentation" --executable "C:\Dokumente und
Einstellungen\All
Users\Anwendungsdaten\AccessGrid\applications\SharedPresentation\SharedP
resentation.py" --description "This is the shared presentation"
--nametemplate "sharedpresentation"
A new line is added to the mailcap file, but when I start Shared
application I get the following output:
C:\Dokumente und Einstellungen\All
\SharedPresentation\SharedPresentation.py:
    -h|--help : print usage
    -a|--applicationURL : <url to application in venue>
    -i|--information : <print information about this application>
    -l|--logging : <log name: defaults to SharedPresentation>
I suppose the -a  parameter is missing. Can you please provide me the
correct script for generating the mailcap entry for shared presentation?
Ferdi
> -----Original Message-----
> From: owner-ag-users at mcs.anl.gov
> [mailto:owner-ag-users at mcs.anl.gov] On Behalf Of Ti Leggett
> Sent: Wednesday, June 18, 2003 12:20 AM
> To: Ferdinand Hommes
> Cc: 'AG Tech'; ag-users at mcs.anl.gov
> Subject: [AG-USERS] RE: [AG-TECH] Problems with access grid
> shared browser
> Yes, in fact that's what I was going to have you do. :)
> >From the command line, if you run:
> python MailcapSetup.py --help
> It should print out some usage information (this assumes
> python is in your path). Here's a quick and dirty tutorial:
> python MailcapSetup.py --mime-type
> "application/x-ag-shared-browser" --executable "C:\Documentst
> and Settings\All Users\Application
> Data\AccessGrid\applications\SharedBrowser\SharedBrowser.py"
> "sharedbrowser"
> That should generate a file in C:\Documents and
> Settings\<username>\Application Data\AccessGrid\mailcap
> Please let me know if there are any errors or if it doesn't
> generate the file. Thanks!
> On Tue, 2003-06-17 at 09:29, Ferdinand Hommes wrote:
> > Yes, mailcapSetup.py is within the AGTk 2.0 directory. Can
> I generate
> > the mailcap file manualy by using this program?
> > > From: Ti Leggett [mailto:leggett at mcs.anl.gov]
> > > Sent: Tuesday, June 17, 2003 4:27 PM
> > > Subject: RE: [AG-TECH] Problems with access grid shared browser
> > > That shouldn't make much difference as it get's the name for
> > > that folder out of the registry. Do you have C:\Program
> > > Files\AGTk 2.0\MailcapSetup.py (replacing c:\Program Files
> > > with wherever you installed it)?
> > > On Tue, 2003-06-17 at 08:49, Ferdinand Hommes wrote:
> > > > Unfortunately I could not find any mailcap files within the
> > > > directories you indicated and within any other directory.
> > > Installation
> > > > und using AGTk have been done with the same Userid. I
> am using the
> > > > German version of Windows XP, which means, that the directory
> > > > c:\Documents and Settings is called c:\Dokumente und
> Einstellungen
> > > > Kind Regards
> > > > Ferdi
> > > > > Sent: Tuesday, June 17, 2003 3:21 PM
> > > > > Cc: AG Tech; ag-users at mcs.anl.gov
> > > > > Subject: Re: [AG-TECH] Problems with access grid
> shared browser
> > > > > For whatever reason you don't have a valid mailcap
> file. Can you
> > > > > send the mailcap file from c:\\Administrator\Application
> > > > > and also from C:\Documents and
> > > > > Data\AccessGrid\mailcap wher <username> is the user you're
> > > > > trying to run as. Also, did you by chance install the AGTk as
> > > > > another user than the one you're currently running as?
> > > > > On Tue, 2003-06-17 at 04:20, Ferdinand Hommes wrote:
> > > > > > Hello,
> > > > > > I am using AG 2.0 with windows XP. When I try to start
> > > the Shared
> > > > > > Browser application I get the following error message:
> > > > > > No Client registered for the selected application
> (mime type =
> > > > > > application/x-ag-shared-browser)
> > > > > > How can I register a client?
> > > > > > Kind regards
> > > > > > Ferdi
> > > > > > Ferdinand Hommes
> > > > > > Fraunhofer-Institut für Medienkommunikation IMK Schloss
> > > > > > Birlinghoven D 53754 Sankt Augustin
> > > > > > Germany
> > > > > > Tel. +49 2241 141932
