[AG-TECH] Problems with access grid shared browser
    Ti Leggett
    leggett at mcs.anl.gov
    Tue Jun 17 17:19:31 CDT 2003
Yes, in fact that's what I was going to have you do. :)
>From the command line, if you run:
python MailcapSetup.py --help
It should print out some usage information (this assumes python is in
your path). Here's a quick and dirty tutorial:
python MailcapSetup.py --mime-type "application/x-ag-shared-browser"
--executable "C:\Documentst and Settings\All Users\Application
Data\AccessGrid\applications\SharedBrowser\SharedBrowser.py"
--description "This is the shared browser" --nametemplate
"sharedbrowser"
That should generate a file in C:\Documents and
Settings\<username>\Application Data\AccessGrid\mailcap
Please let me know if there are any errors or if it doesn't generate the
file. Thanks!
On Tue, 2003-06-17 at 09:29, Ferdinand Hommes wrote:
> Yes, mailcapSetup.py is within the AGTk 2.0 directory. Can I generate
> the mailcap file manualy by using this program?
> > -----Original Message-----
> > From: Ti Leggett [mailto:leggett at mcs.anl.gov]
> > Sent: Tuesday, June 17, 2003 4:27 PM
> > To: Ferdinand Hommes
> > Cc: 'AG Tech'; ag-users at mcs.anl.gov
> > Subject: RE: [AG-TECH] Problems with access grid shared browser
> > That shouldn't make much difference as it get's the name for
> > that folder out of the registry. Do you have C:\Program
> > Files\AGTk 2.0\MailcapSetup.py (replacing c:\Program Files
> > with wherever you installed it)?
> > On Tue, 2003-06-17 at 08:49, Ferdinand Hommes wrote:
> > > Unfortunately I could not find any mailcap files within the
> > > directories you indicated and within any other directory.
> > Installation
> > > und using AGTk have been done with the same Userid. I am using the
> > > German version of Windows XP, which means, that the directory
> > > c:\Documents and Settings is called c:\Dokumente und Einstellungen
> > > Kind Regards
> > > Ferdi
> > > > Sent: Tuesday, June 17, 2003 3:21 PM
> > > > Cc: AG Tech; ag-users at mcs.anl.gov
> > > > Subject: Re: [AG-TECH] Problems with access grid shared browser
> > > > For whatever reason you don't have a valid mailcap file. Can
> > > > you send the mailcap file from c:\\Administrator\Application
> > > > and also from C:\Documents and
> > > > Settings\<username>\Application Data\AccessGrid\mailcap wher
> > > > <username> is the user you're trying to run as. Also, did you
> > > > by chance install the AGTk as another user than the one
> > > > you're currently running as?
> > > > On Tue, 2003-06-17 at 04:20, Ferdinand Hommes wrote:
> > > > > Hello,
> > > > > I am using AG 2.0 with windows XP. When I try to start
> > the Shared
> > > > > Browser application I get the following error message:
> > > > > No Client registered for the selected application
> > > > > (mime type = application/x-ag-shared-browser)
> > > > > How can I register a client?
> > > > > Kind regards
> > > > > Ferdi
> > > > > Ferdinand Hommes
> > > > > Fraunhofer-Institut für Medienkommunikation IMK
> > > > > Schloss Birlinghoven
> > > > > D 53754 Sankt Augustin
> > > > > Germany
> > > > > Tel. +49 2241 141932
