[AG-TECH] Packaging a Shared Application for AG 2
    Ti Leggett
    leggett at mcs.anl.gov
    Tue Jun 17 17:23:17 CDT 2003
Based on the fact that you say you don't have the tools to create an
installer I'm guessing this is for windows. If it is, check out the mail
I just replied to about "Problems with access grid shared browser". If
you're serious about it the shared app, then you'll want to package it
because it will make things easier to debug and test, believe or not.
I'd download InnoSetup and ISTool (you can find the links if you google
for InnoSetup). Once you have that, check out the AccessGrid cvs module
and take a look at AccessGrid/sharedapps/SharedBrowser/SharedBrowser.iss
On Tue, 2003-06-17 at 16:01, Allan Spale wrote:
> Hello,
> I would like to know how it would be possible to test a shared application
> for AG 2.  Because it is necessary to associate a MIME type with the
> shared application, it would seem necessary to perform some sort of
> instalation of the software in order to create this association.
> Currently, I do not have the capability to create some sort of
> installation package that would put things in the correct place.  Without
> this capability, how can I test the shared application to see if it works
> correctly with AG 2?
> Thanks.
> Allan
> EVL at UIC
> Research Assistant
