[AG-TECH] Problems with access grid shared browser
Ferdinand Hommes
Ferdinand.Hommes at imk.fraunhofer.de
Tue Jun 17 09:29:58 CDT 2003
Yes, mailcapSetup.py is within the AGTk 2.0 directory. Can I generate
the mailcap file manualy by using this program?
> -----Original Message-----
> From: Ti Leggett [mailto:leggett at mcs.anl.gov]
> Sent: Tuesday, June 17, 2003 4:27 PM
> To: Ferdinand Hommes
> Cc: 'AG Tech'; ag-users at mcs.anl.gov
> Subject: RE: [AG-TECH] Problems with access grid shared browser
> That shouldn't make much difference as it get's the name for
> that folder out of the registry. Do you have C:\Program
> Files\AGTk 2.0\MailcapSetup.py (replacing c:\Program Files
> with wherever you installed it)?
> On Tue, 2003-06-17 at 08:49, Ferdinand Hommes wrote:
> > Unfortunately I could not find any mailcap files within the
> > directories you indicated and within any other directory.
> Installation
> > und using AGTk have been done with the same Userid. I am using the
> > German version of Windows XP, which means, that the directory
> > c:\Documents and Settings is called c:\Dokumente und Einstellungen
> > Kind Regards
> > Ferdi
> > > Sent: Tuesday, June 17, 2003 3:21 PM
> > > Cc: AG Tech; ag-users at mcs.anl.gov
> > > Subject: Re: [AG-TECH] Problems with access grid shared browser
> > > For whatever reason you don't have a valid mailcap file. Can
> > > you send the mailcap file from c:\\Administrator\Application
> > Data\AccessGrid\mailcap
> > > and also from C:\Documents and
> > > Settings\<username>\Application Data\AccessGrid\mailcap wher
> > > <username> is the user you're trying to run as. Also, did you
> > > by chance install the AGTk as another user than the one
> > > you're currently running as?
> > > On Tue, 2003-06-17 at 04:20, Ferdinand Hommes wrote:
> > > > Hello,
> > > > I am using AG 2.0 with windows XP. When I try to start
> the Shared
> > > > Browser application I get the following error message:
> > > > No Client registered for the selected application
> > > > (mime type = application/x-ag-shared-browser)
> > > > How can I register a client?
> > > > Kind regards
> > > > Ferdi
> > > > Ferdinand Hommes
> > > > Fraunhofer-Institut für Medienkommunikation IMK
> > > > Schloss Birlinghoven
> > > > D 53754 Sankt Augustin
> > > > Germany
> > > > Tel. +49 2241 141932
