[AG-TECH] Problems with access grid shared browser
    Ti Leggett
    leggett at mcs.anl.gov
    Tue Jun 17 09:27:28 CDT 2003
That shouldn't make much difference as it get's the name for that folder
out of the registry. Do you have C:\Program Files\AGTk
2.0\MailcapSetup.py (replacing c:\Program Files with wherever you
installed it)?
On Tue, 2003-06-17 at 08:49, Ferdinand Hommes wrote:
> Unfortunately I could not find any mailcap files within the directories
> you indicated and within any other directory. Installation und using
> AGTk have been done with the same Userid. I am using the German version
> of Windows XP, which means, that the directory c:\Documents and
> Settings is called c:\Dokumente und Einstellungen
> Kind Regards
> Ferdi
> > -----Original Message-----
> > From: Ti Leggett [mailto:leggett at mcs.anl.gov]
> > Sent: Tuesday, June 17, 2003 3:21 PM
> > To: Ferdinand Hommes
> > Cc: AG Tech; ag-users at mcs.anl.gov
> > Subject: Re: [AG-TECH] Problems with access grid shared browser
> > For whatever reason you don't have a valid mailcap file. Can
> > you send the mailcap file from c:\\Administrator\Application
> Data\AccessGrid\mailcap
> > and also from C:\Documents and
> > Settings\<username>\Application Data\AccessGrid\mailcap wher
> > <username> is the user you're trying to run as. Also, did you
> > by chance install the AGTk as another user than the one
> > you're currently running as?
> > On Tue, 2003-06-17 at 04:20, Ferdinand Hommes wrote:
> > > Hello,
> > > I am using AG 2.0 with windows XP. When I try to start the Shared
> > > Browser application I get the following error message:
> > > No Client registered for the selected application
> > > (mime type = application/x-ag-shared-browser)
> > > How can I register a client?
> > > Kind regards
> > > Ferdi
> > > Ferdinand Hommes
> > > Fraunhofer-Institut für Medienkommunikation IMK
> > > Schloss Birlinghoven
> > > D 53754 Sankt Augustin
> > > Germany
> > > Tel. +49 2241 141932
