[AG-TECH] Problems with access grid shared browser
    Ferdinand Hommes
    Ferdinand.Hommes at imk.fraunhofer.de
    Tue Jun 17 08:49:37 CDT 2003
Unfortunately I could not find any mailcap files within the directories
you indicated and within any other directory. Installation und using
AGTk have been done with the same Userid. I am using the German version
of Windows XP, which means, that the directory c:\Documents and
Settings is called c:\Dokumente und Einstellungen
Kind Regards
Ferdi
> -----Original Message-----
> From: Ti Leggett [mailto:leggett at mcs.anl.gov]
> Sent: Tuesday, June 17, 2003 3:21 PM
> To: Ferdinand Hommes
> Cc: AG Tech; ag-users at mcs.anl.gov
> Subject: Re: [AG-TECH] Problems with access grid shared browser
> For whatever reason you don't have a valid mailcap file. Can
> you send the mailcap file from c:\\Administrator\Application
Data\AccessGrid\mailcap
> and also from C:\Documents and
> Settings\<username>\Application Data\AccessGrid\mailcap wher
> <username> is the user you're trying to run as. Also, did you
> by chance install the AGTk as another user than the one
> you're currently running as?
> On Tue, 2003-06-17 at 04:20, Ferdinand Hommes wrote:
> > Hello,
> > I am using AG 2.0 with windows XP. When I try to start the Shared
> > Browser application I get the following error message:
> > No Client registered for the selected application
> > (mime type = application/x-ag-shared-browser)
> > How can I register a client?
> > Kind regards
> > Ferdi
> > Ferdinand Hommes
> > Fraunhofer-Institut für Medienkommunikation IMK
> > Schloss Birlinghoven
> > D 53754 Sankt Augustin
> > Germany
> > Tel. +49 2241 141932
