[AG-TECH] grid-proxy-init
    Ti Leggett
    leggett at mcs.anl.gov
    Mon Jun 16 15:56:10 CDT 2003
Try this. As someone other than root, generate a new key and request.
Then when you have the signed certificate, try running grid-proxy-init
as a normal user.
On Mon, 2003-06-16 at 15:44, Coorpender, Steven wrote:
> I am running Red Hat 7.3 -- 2.4.20-18.7smp
> Output from [ls -l ~/.globus/*] is:
> total 12
> -rw-r--r--    1 root     root         3685 Jun 16 13:36 usercert.pem
> -rw-r--r--    1 root     root         1607 Jun 16 11:33
> usercert_request.pem
> -r--------    1 root     root          963 Jun 16 11:33 userkey.pem
> Output from [which grid-proxy-init] is:
> /usr/lib/globus/bin/grid-proxy-init
> Output from [ldd `which grid-proxy-init`] is:
> libglobus_ssl_utils_gcc32pthr.so.0 =>
> /usr/lib/globus/lib/libglobus_ssl_utils_gcc32pthr.so.0 (0x40014000)
>         libssl_gcc32pthr.so.0 =>
> /usr/lib/globus/lib/libssl_gcc32pthr.so.0 (0x40025000)
>         libcrypto_gcc32pthr.so.0 =>
> /usr/lib/globus/lib/libcrypto_gcc32pthr.so.0 (0x40054000)
>         libdl.so.2 => /lib/libdl.so.2 (0x40132000)
>         libpthread.so.0 => /lib/i686/libpthread.so.0 (0x40135000)
>         libc.so.6 => /lib/i686/libc.so.6 (0x42000000)
>         /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
> Thanks,
> Steven
> -----Original Message-----
> From: Ti Leggett [mailto:leggett at mcs.anl.gov]
> Sent: Monday, June 16, 2003 3:26 PM
> To: Coorpender, Steven
> Cc: 'ag-tech at mcs.anl.gov'
> Subject: Re: [AG-TECH] RE: [AG-USERS] grid-proxy-init
> What platform are you trying to run this on? What's the output from:
> ls -l ~/.globus/*
> and
> On Mon, 2003-06-16 at 15:15, Coorpender, Steven wrote:
> > I am getting the exact same problem. Segmentation fault when running
> > grid-proxy-init. Does anyone know how to fix this? Thanks.
> > From: Sravan Kudithipudi [mailto:sravan at ccs.uky.edu]
> > Sent: Friday, June 13, 2003 8:47 AM
> > To: ag-users at mcs.anl.gov
> > Subject: [AG-USERS] grid-proxy-init
> > Hello Everyone,
> >  I had a problem running grid-proxy-init on my system when i was
> > trying to make the node work for AG 2.0. I copied the usercert.pem
> to
> > .globus of my working directory.
> >  When i tried executing the grid-proxy-init it gave me segmentation
> > fault. Could anyone tell me what could have caused the fault and any
> > debugging tools. I tried with gdb but not successful.
> > Thanks
> > -Sravan
