..Re: [AG-TECH] Rat forwarding
Jason Hill
jahill at scl.ameslab.gov
Mon Jun 16 14:03:05 CDT 2003
Vandana
I installed on Debian - so some steps may be different for you, but here
goes:
It seems your OS doesn't know where to locate AGNodeService.py . When I
converted the rpm packages to debian packages and installed them, it
placed that file in /usr/bin . Try looking there for AGNodeService,
AGServiceManager, and NodeManagement.py. At the prompt you could try :
$> /usr/bin/AGNodeService.py
That should start the script.
I also found it very helpful to download the CVS for the AGTK and look
into the documentation, particularly the RoomBasedNode-HOWTO.doc file.
It will be located in the docs directory in the folder you choose to
install it in.
Hope that helps.
-Jason
Jason Hill
SCL, Ames Laboratory
310 Wilhelm Hall
Ames, IA 50010
Vandana wrote:
>Hi,
> I am actually trying to install AG2.0 on a Linux machine 7.3. After I
>run grid-proxy-init and then try to run AGNodeService.py it says command
>not found. Any suggestions.
> What documentation are you following for Linux. Please forward me the
>link if possible.
>Thanks & Regards,
>Vandana Chopra
>On Fri, 13 Jun 2003, Jason Hill wrote:
>>Has anyone using only Linux been successful in forwarding the rat
>>session from the capture machine to the display machine?
>>Thanks,
>>-Jason
>>Jason Hill
>>Ames, IA 50010
