[AG-TECH] Local AGTk2.0 VenueServer Problem.
    Andrew Bolyea
    andrew.bolyea at sheridanc.on.ca
    Fri Jun  6 16:29:26 CDT 2003
Nope, no luck...  The same error appears in the log.
-Andrew.
----- Original Message -----
Date: Friday, June 6, 2003 5:08 pm
Subject: Re: [AG-TECH] Local AGTk2.0 VenueServer Problem.
> Andrew:
> Try removing VenueServer.cfg.  This file stores the configuration
> of the
> venue server.  Therein is an option for the default venue, which
> appears
> not to exist.  The venue doesn't exist, so no Enter method is
> found.
> (Yes, the error should say that the URL is invalid, not that the
> method
> is not found.)
> If that doesn't fix the problem, let me know.
> Tom
> Andrew Bolyea wrote:
> >I had setup an AG2RC1 VenueServer a few weeks ago, and
> >everything worked very well.  My AG2RC1 VenueClient could
> >connect to it without any problems.
> >Today I wiped my VenueServer clean, and installed the new
> >AG2.0 VenueServer.  Now I can't connect to it anymore.  I
> >am using the new AG2.0 VenueClient as well.  I have no
> >problems connecting to the default VenueServer (vv2.mcs...)
> >Any ideas?  Any help would be appreciated.
> >Thanks,
> >Andrew.
> >Here is the VenueClient.log:
> >06/06/03 16:26:57 608 AG.Types venueclient.py:649 DEBUG
> bin.VenueClient::EnterVenue: Enter venue with url: https://oa-ag-
> venue.sheridanc.on.ca:8000/VenueServer>06/06/03 16:26:57 608
> AG.CertificateManager certificatemanager.py:1146 DEBUG Loaded
> certificate for /O=Access Grid/OU=agdev-
> ca.mcs.anl.gov/OU=sheridanc.on.ca/CN=ag/CN=proxy>06/06/03 16:26:57
> 608 AG.CertificateManager certificatemanager.py:363 DEBUG Proxy
> C:\DOCUME~1\AG\LOCALS~1\Temp\proxy is valid
> >06/06/03 16:26:57 608 AG.Types venueclient.py:856 DEBUG Set
> history url: None
> >06/06/03 16:26:57 608 AG.Types venueclient.py:775 ERROR
> bin.VenueClient::EnterVenue failed
> >Traceback (most recent call last):
> >  File "VenueClient.py", line 676, in EnterVenue
> >    warningString = VenueClient.EnterVenue( self, URL )
> >  File "C:\Python22\Lib\site-packages\AccessGrid\VenueClient.py",
> line 264, in EnterVenue
> >    (venueState, self.privateId, streamDescList ) =
> Client.Handle( URL ).get_proxy().Enter( self.profile )
> packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3650, in
> __call__>    return self.__r_call(*args, **kw)
> packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3670, in
> __r_call>    self.__hd, self.__ma)
> packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3585, in
> __call>    raise p
> >faultType: <Fault SOAP-ENV:Client: No method Enter found>
