[AG-TECH] Local AGTk2.0 VenueServer Problem.
Thomas Uram
turam at mcs.anl.gov
Fri Jun 6 16:39:23 CDT 2003
I should have had you remove VenueServer.cfg and VenueServer.dat.
Tom
Andrew Bolyea wrote:
>Nope, no luck... The same error appears in the log.
>-Andrew.
>----- Original Message -----
>From: Thomas Uram <turam at mcs.anl.gov>
>Date: Friday, June 6, 2003 5:08 pm
>Subject: Re: [AG-TECH] Local AGTk2.0 VenueServer Problem.
>>Andrew:
>>Try removing VenueServer.cfg. This file stores the configuration
>>of the
>>venue server. Therein is an option for the default venue, which
>>appears
>>not to exist. The venue doesn't exist, so no Enter method is
>>found.
>>(Yes, the error should say that the URL is invalid, not that the
>>method
>>is not found.)
>>If that doesn't fix the problem, let me know.
>>Tom
>>>I had setup an AG2RC1 VenueServer a few weeks ago, and
>>>everything worked very well. My AG2RC1 VenueClient could
>>>connect to it without any problems.
>>>Today I wiped my VenueServer clean, and installed the new
>>>AG2.0 VenueServer. Now I can't connect to it anymore. I
>>>am using the new AG2.0 VenueClient as well. I have no
>>>problems connecting to the default VenueServer (vv2.mcs...)
>>>Any ideas? Any help would be appreciated.
>>>Thanks,
>>>Andrew.
>>>Here is the VenueClient.log:
>>>06/06/03 16:26:57 608 AG.Types venueclient.py:649 DEBUG
>>bin.VenueClient::EnterVenue: Enter venue with url: https://oa-ag-
>>venue.sheridanc.on.ca:8000/VenueServer>06/06/03 16:26:57 608
>>AG.CertificateManager certificatemanager.py:1146 DEBUG Loaded
>>certificate for /O=Access Grid/OU=agdev-
>>ca.mcs.anl.gov/OU=sheridanc.on.ca/CN=ag/CN=proxy>06/06/03 16:26:57
>>608 AG.CertificateManager certificatemanager.py:363 DEBUG Proxy
>>C:\DOCUME~1\AG\LOCALS~1\Temp\proxy is valid
>>>06/06/03 16:26:57 608 AG.Types venueclient.py:856 DEBUG Set
>>history url: None
>>>06/06/03 16:26:57 608 AG.Types venueclient.py:775 ERROR
>>bin.VenueClient::EnterVenue failed
>>>Traceback (most recent call last):
>>> File "VenueClient.py", line 676, in EnterVenue
>>> warningString = VenueClient.EnterVenue( self, URL )
>>> File "C:\Python22\Lib\site-packages\AccessGrid\VenueClient.py",
>>line 264, in EnterVenue
>>> (venueState, self.privateId, streamDescList ) =
>>Client.Handle( URL ).get_proxy().Enter( self.profile )
>>packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3650, in
>>__call__> return self.__r_call(*args, **kw)
>>packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3670, in
>>__r_call> self.__hd, self.__ma)
>>packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3585, in
>>__call> raise p
>>>faultType: <Fault SOAP-ENV:Client: No method Enter found>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030606/3a15482e/attachment.htm>
